04-11-12, 10:29 AM | #1 |
Controlling a DC inverter machine
As I have just been given a Daikin split system which has a DC compressor I started thinking about how to control it.
The threads I have read have all focussed on using controllers from various devices and adapting them. This involves 'junking' the existing control system and starting from scratch building a DC motor controller. Has anyone succeeded in doing this? I still don't know if the units I have actually function, that's still to test, but assuning they do I'm firstly going to try a different approach. What would be wrong with gutting the internal unit and then using it in abox to control the external unit? The unit I have has 1 thermal sensor and the remote that signalls to the unit what to do. Why re-invent the wheel as far as the external unit is concerned? So my plan is: 1. Get the unit working with the existing internal unit control board removed from the internal unit. 2. 'Crack' the control code - unless it is detailled in the service manual (that I'm hoping to get hold of). It signalls down 1 wire (certainly referenced to ground or neutral so I should be able to monitor it). 3. Build my own controller to manage the external unit. Any thoughts/suggestions? Nigel |
