Old 01-10-11, 05:28 PM   #271
gogigaga
@xringer. I cannot send PM's the system does not let me to. Says I need to post at least 15 times. This is my 4th post so one more and I should be able to post pictures.
gogigaga is offline   Reply With Quote
Old 01-10-11, 05:40 PM   #272
gogigaga
Now that I can post the images.
This is how it looked like when it started getting oval.
Then I continued bending the bigger pipe at a different place without dowel. I think it looks a little better but will it work? This is how it looks now.
Old 01-10-11, 06:20 PM   #273
That doesn't look bad in the second picture. A little flat spot doesn't really reduce the the flow that much. It should work just fine.
When I was bending the line set tubes down at the outdoor unit connections,
I started getting a flat spot. I just stopped and moved up the line a little and finished the bend.
I think the fat item I was trying to use for a dowel had slipped a little and caused a bit of a too-tight bend.
I didn't try if 'fix' it, since it was so slight. I just moved the bend down the tube.
Here's a real kink in a heat pump line..
From here: Heat pump - InterNACHI Message Board
gogigaga (01-10-11)
Old 01-10-11, 06:35 PM   #274
gogigaga
That is a relief. I did exactly what you explained in you post. The only difference is in my case the dowel was making a bigger curve which did not fit in the slimduct. So I just moved a little backward and bent the pipe starting inside the wall sleeve as much as possible. The big pipe on the LG is not that soft.
Old 01-10-11, 06:40 PM   #275
It looked pretty dang big in the pics. What's the BTUs?
Old 01-10-11, 06:46 PM   #276
gogigaga
It's a closeup shot from my iPhone. The Unit is 12000 BTU. It looks big because there is no other context to compare in the picture.
Old 01-10-11, 06:58 PM   #277
Actually, there is a hand in the background.. But, it could be a baby's hand.?.
Or maybe the hand of a petite woman?
Old 01-11-11, 05:05 AM   #278
I looked up some specs on the LG 12k BTU units and it looks like most of their units use 1/4" and 1/2" lines a few of their units use 1/4" and 3/8" lines, with the 3/8" being part of the more efficient 18.7 and 20 SEER models I ran into.
It seems Fujitsu has 1/4" and 3/8" lines on their super high SEER 9k(26) and 12k(25) units.
gogigaga, Is your lineset 1/4" and 1/2" lines?
Old 01-11-11, 11:20 AM   #279
gogigaga
This is the LG Artcool 12K btu unit. The lines are 1/4" and 3/8".
@Xringer, that is my hand in the picture
Old 01-11-11, 11:35 AM   #280
Those ArtCool indoor units are the best looking. I'm glad my wife didn't
see those before I got the Sanyo. I like the functional look myself.
But, now that our living room has been re-done..?.
Maybe our next system will have a stylish indoor unit..
I was just kidding about the hand.. I have smallish hands for a big guy.
I shoulda been a surgeon!
So, how is the work coming? Doing a pressure test? Or going right to
the vacuum pump?
I think pressure testing is a good idea, due to the shape of the flare.
IMHO, it's going to seal tighter under vacuum, but under pressure,
if there are any problems, they should show up quickly at high PSI.
