Old 07-14-10, 06:58 AM   #91
Default OT, but interesting..
BTW...
This is very off topic, but here's an interesting How-To:
How to Convert a Computer ATX Power Supply to a Lab Power Supply.
Those things are pretty well made.. At least this design looks nice..
200W ATX PC POWER SUPPLY
Wow! 300vdc! The 120-240 switching is simple anyways..
Old 07-14-10, 02:16 PM   #92
Default Help!
Originally Posted by jrandom_EE View Post
I think first getting an idea of the appropriate static pressure needed would be a good first step. Make a manometer tube, use an over-sized fan, and block it until it gives the right flow rate. A simple hack method of measuring would be using a cylindrical outlet and wafting smoke from an incense stick down it, and calculating the CFM from the rate of movement of the smoke. Then use that to look up the right fan.
I have a dandy blower to do tests with but I can't make it work.
It's a capacitive-start AC motor.
Here's a photo of the wires & connector:
Here's a photo of the connector with the DC resistance I measured across the various terminal combinations:
...and here's a photo of the only identification on the fan:
The fan came from a range hood blower. This fan was one of two., the other motor has a broken internal support. As I read the label, it says Elica, which seems to be a maker of range hoods made in Italy.
I searched for "Elica schematic", "Elica wiring", "Elica diagram", but wasn't able to find any helpful info.
Any ideas?
ID:	852   Click image for larger version
ID:	853   Click image for larger version
Old 07-14-10, 03:49 PM   #93
Default Brushless DC Motor Control using ATmega32M1
Quite by accident, I came across this app note:
Looks like the ATmega32M1 is similar to the processor used by the Arduino community plus a Power Stage Controller.
Old 07-17-10, 07:48 PM   #94
jrandom_EE
Sorry AC Hacker, I'm not familiar with US wiring, so I wouldn't want to speculate on how to wire it up correctly. I'm also not really a power EE, and haven't done anything in that area since university anyway. I'd be just googling the same as you.
jrandom_EE is offline   Reply With Quote
Old 07-17-10, 08:26 PM   #95
There is some stuff around on the web.. Is there a switch in that fan unit?
One that opens, when the fan motor starts running?
I had one of those flying balls centrifugal gizmos on an old oil burner motor once.
It broke one night at 3AM.. I drilled two small holes in some spring thing that held
one of the weights and tied them together with a paper clip..
It worked for years, until the system was replaced..
Connecting the CSIR Motor for a Change of Rotation
http://i110.photobucket.com/albums/n...ack/baldor.jpg
http://img.photobucket.com/albums/v4...nut/SBLMTR.jpg
igor.chudov.com/manuals/ElectricMotors.pdf
Old 07-18-10, 09:12 AM   #96
...I'm not familiar with US wiring...
jrandom,
This is actually a euro-fan. Made in Italy I suspect and sold all over Europe and apparently also sold in the US.
So your knowledge might be relevant.
Old 07-18-10, 09:14 AM   #97
... and tied them together with a paper clip...
Xringer,
Thanks for the links.
I'll check them out.
Old 09-02-10, 12:58 PM   #98
laderload
Hi,
i am new to this great group and i would like to thank you all for your contributions and thoughtful work. also i did not find the usual off topic sliding on private or ego issues
thank you Dave Meinert for sharing your work and showing us that this is feasable and working.
i am going to start building these weeks and would like to ask if any of the "plastic " versions have been finished and are working?
is there anyone who tried the metal version in comparison?
also, did someone experiment with the old AC/dehumidifiers (the surface is great, but just not even for both streams, due to the water-air mechanism )?
thank you very much for your help
laderload
laderload is offline   Reply With Quote
Old 09-02-10, 01:57 PM   #99
Originally Posted by laderload View Post
Hi,
Welcome to EcoRenovator. Please drop a few lines about yourself and your planned and finished projects in the Introductions section.
Old 09-02-10, 03:35 PM   #100
My plastic version is on hold due to other projects.
erv, heat recovery, hrv
