Go Back   EcoRenovator > Introductions
Old 12-09-12, 11:55 AM   #1
Pilgrim
Default Romania says "cheers"
Hi everybody, as the everlastig note says, I'm "saying hello to our community in our Introductions forum."
I'm a romanian tinkerer, got 2 wells (10 m deep) and seriously reading GSHP thread, because I will learn to use my well water to heat (maybe cool too) my home.
Did try HCS on automotive field (1995 E200 MB) with no obvious positive results (old sensors, smart car calculator which couldn't be tricked yet).
Open minded to any reasonable economy mod.
Yours,
Stefan
Pilgrim is offline   Reply With Quote
Old 12-09-12, 01:50 PM   #2
Piwoslaw
Piwoslaw's Avatar
If you've got 2 wells, then you are off to a good start!
I take it you've read the Home Energy Saving Tips.
If you want to save with your car, then check out EcoModder.com.
BTW, What is HCS?
The Following User Says Thank You to Piwoslaw For This Useful Post:
Pilgrim (12-10-12)
Old 12-09-12, 08:10 PM   #3
Welcome to the site Stefan. Piwoslaw has some good suggestions.
Pilgrim (12-10-12)
Old 12-10-12, 12:13 AM   #4
Pilgrim
HCS = Hidrocarbon Cracking System. There is a dedicated (may be more) thread. You vacuum gasoline fumes / vapors through a line close to the exhaust manifold, in order to improve combustion. But, in a Fuel Injected engine, the computer must be fooled into thinking there is a rich mixture (EFIE). Mine was smarter than that
Old 12-10-12, 06:04 AM   #5
Exalta-STA
Welcome aboard Pilgrim!
Exalta-STA is offline   Reply With Quote
