Old 06-09-10, 12:04 PM   #11
wilfor03
Default Tracker Board Performance
Hey Xringer.....have you gotten the bugs worked out of your controller board yet? You were having problems with the "west" tracking function and return-at-night function? I've tried to get ahold of Duane @ RedRok and no response yet.....soooooooooooo...I think I may give the MTM Scientific board a try....Just really curious before I buy, ya know.....Thanks a bunch.....Bill
wilfor03 is offline   Reply With Quote
Old 06-09-10, 12:26 PM   #12
I ended up adding a pot to the reference voltage divider and got better tracking. (per the manual).
But since I've moved the mount, (and left the ground rod), I seem to be picking up
some RFI in my long sensor head cable.. The local AM station is less than 2 miles away.
The night return function works great. But only when it's dark..
The 'lost' west tracking problem is still there, because I have not moved the
West sensor up closer to the glass. (I plan to do that someday)!
It only gets lost when it's a very cloudy morning and the sun comes out at lunchtime..
I'm still thinking of just adding a West button to the control box..
Just now, I've added to 47 uF caps across the light sensor input lines..
I hope that might reduce the reply clicking some. (From clouds and leaves etc).
It might also help the RFI (if that's the problem).
The board is easy to use, easy to assemble, but be prepared to tinker with it a bit.
Old 06-09-10, 01:12 PM   #13
wilfor03
Default Tinkering with the board
Thanks Xringer.....I might just give it a shot and hollar your way if I run into troubles (needing help, or whatever, eh?).....thanks abunch.....Bill
Old 06-10-10, 06:03 PM   #14
wilfor03
Thumbs up New PCB
Wooo-Whooooo....just got an email from MTM Scientific that they shipped my tracker board.....probably get maybe Monday.....I'll post pictures of whats going on with it.....this is the last I have to do to get the "system" automated. Appreciate the help, Rich.....Bill
Old 06-10-10, 08:31 PM   #15
Cool! Now you will be able to just sit back and watch it track!
IIRC, I somehow blasted my chip. It's an LP339 and I replaced it with a Radio Shack part..
LM339 Quad Comparator (14-Pin DIP) Model: LM339 | Catalog #: 276-1712 $1.49
I even picked up an extra chip for a spare. Of course it will never be needed
until the day I lose it.. Murphy effect..
Anyways, if your actuator has limit switches built in, you will need to install
some shorty jumpers in those middle terminal pairs.
http://i46.photobucket.com/albums/f1...arControls.jpg
How do you plan to mount the photocells?? PB jar??
Old 06-11-10, 12:28 PM   #16
wilfor03
Hey Xringer....are you talking about the 2-each E switch/W switch terminals I blew the picture up to see)? Yeah, I'm gonna put them in some sort of clear jar on the north-east top of the solar array. Should only be bout 3 1/2' from where they'll be mounted to where the board is? Think that will work.....Bill
Old 06-11-10, 03:49 PM   #17
The E & W switches are the East and West end-limit switches.
If you don't have out-board switches (if your actuator has limit switches built in),
you will need to add a couple of jumpers..
You should use 2-pair wire (2 twisted pair) to connect to the photocells.
My cable is about 10 feet long. (In case I want to move it higher on the array).
I've seen some clear jar setups, and I always wondered about the heat
build-up and condensation inside the jar.
But, I had to get fancy and ended up with too much West side blockage..
Very soon, I'm yanking that thing down and moving the West side
photocell much closer to the glass.. Hopefully, that will help.
I know that days like today will be the challenge, (the sun came out at 3PM)
and it's going to take something well designed to work well..
Old 06-11-10, 04:24 PM   #18
wilfor03
10-4 on the jumper wires....my actuator has the built in limit switches. Did you get your actuator fixed up? How did you mount your photo-resistors? On a piece of veroboard or???? You just got me thinking about that? no sleep tonite (LOL).....Bill :eek
Old 06-11-10, 04:39 PM   #19
My actuator is okay. I just used a metal divider between the photocells.
The pictures are here: http://ecorenovator.org/forum/projec....html#post5718
I painted the inside of the module flat-black and put heat shrink on the leads,
so they wouldn't short out..
Old 06-15-10, 01:03 PM   #20
wilfor03
Talking Pcb
Yea...my circuit board just arrived today! Looks really good (and simple) with all the parts and PCB. Hopefully, tonight, I'll start putting it together and test it out outside in the morning (if there's any sun). I'll keep you guys posted.....Bill
