Old 03-13-13, 10:27 PM   #1
Drake
DIY Guy
Default Off-peak elec storage hot water?
This is an option being promoted by elec coop where I am building retirement home. I understand how it works I just am not confident that water usage wouldn't quickly mix lower tank temp between off-peak heating periods. As my wife and I will be working to adopt a water and energy conservative lifestyle with just the two of us I am exploring whether a smaller whole house elec tankless water heater might be a better direction. Heat pump H2O heaters look interesting but our heating season is as long as our cooling season so finding the interior heat for the pump to collect without paying for it has to be considered. Summer cooling would be a plus though.
Old 03-14-13, 10:12 AM   #2
Drake,
First, what is the differential between the peak and off peak rate? Also look at the availability of natural gas as that option is almost always cheaper that using electricity to heat water.
I have a client that does not have access to natural gas, but very inexpensive off peak electricity cost ($0.03) vs almost triple on peak. We suggested two tanks with one tank just for preheating water at night.
Even if you have one tank, there is not much mixing between the top of the tank and the lower part.
Does this help?
Old 03-14-13, 01:51 PM   #3
Drake
DIY Guy
No natural gas available and LP expensive and going up. Off-peak rate(.04/Kw) slightly less than half regular rate. And your input does help never had experience with bigger than 40 gal tank. Coop have good incentives for off-peak consumption to consider. Also see more possibliities in self elec generation. No indoor combustion either.
Old 03-15-13, 09:35 PM   #4
If you already have an electric water heater, all you need to do is add a timer.
Old 03-16-13, 08:37 AM   #5
The mixing of the hot and cold water is pretty slow, you should drain the sediment off your current water heater every few months as it is if you want it to keep it's warranty and in doing so you will notice that you can pull cold water out of the bottom of your hot water heater tank pretty easily.
Question is, do you want to use LESS energy or CHEAPER energy.
I like your idea of an off peek tempering tank then a small 3 to 5 gallon hot water tank that you super insulate and you could even have that small tank super close to your point of use for instant hot water.
Like has bee suggested already, a timer that you install, while it might not be connected to the off peek meter (if you have two meters) it will cut your KWH use by not allowing your water heater to reheat water at 2am from standby heat loss.
Old 03-16-13, 09:54 AM   #6
Being retired means less hotwater use in my house. We are using the Airtap A7
and it works okay down to 44F in the basement.
AirTap: A Heat Pump For Your Hot Water Heater: Hot or Not? : TreeHugger
It's not UL listed..
You might like one of the new Hybrid DHW heater.. A lot of folks use these in ASHP mode only..
Water Heater FAQs, Hot Water Heaters | GE Appliances
Old 03-20-13, 11:14 AM   #7
Drake
DIY Guy
Here a separate meter is needed for off peak pricing and a minimum # of gals to off peak heat tank storage to get into program. I did find out that A HP DHWH could be part of that storage system. If I find one for a bargain price I think the summer savings,cooling and dehumidification a potential positive. I know summer solar water heating is at its peak but going to be grid-tied so I favor collector space for PV, which is less potential trouble in long winter area IMO.
Old 03-20-13, 11:16 AM   #8
Drake
DIY Guy
Some good deals on HP DHWHs on Ebay but most won't ship. Too bad.
Old 03-20-13, 04:55 PM   #9
With an 80 gallon tank connected to an A7 operating off-peak only, you should never have to worry about running out of hot water. Your electric bill should feel a stiff one-two punch, saving you thousands of dollars over time.
Old 03-22-13, 08:54 AM   #10
That sounds like a good idea Jeff5may.
