Old 09-01-14, 11:46 AM   #1
Default Poly-Iso Insulating Foam R-value is Changing...
Various foam R-values get discussed a lot on this forum, so I thought it would be of interest to know that new testing procedures are being applied.
R-value is being reduced from R-6/inch to R-5.7/inch
SEE_ANNOUNCEMENT
There could be other changes to other materials, too.
buffalobillpatrick (09-11-14), Daox (09-01-14)
Old 09-01-14, 06:37 PM   #2
The same holds true for 2lb urethane foam and isonine foam. Long term tests show a settling of R values for most foams.
