#11 |
![]() I have used the drill and the chain saw a bunch of times. They are working well.
I just ordered a Hedge Trimmer that uses the same battery. It was $43.95 shipped. It is funny as I don’t have any hedges. I will use it for a quick grass trim in front greenhouse. Some brush as the lake. So for a $145.95 I now have a drill, small chainsaw 10", weed eater and a hedge trimmer.
#12 |
![]() Two years later I still use my 24Volt greenworks equipment.
I would like a second battery. I just ordered a blower and a weed trimmer for this house. It was a combo kit blower weed trimmer battery charger $96 shipped. Lowes had the kit. Not as good a deal as the $35 trimmer but not to bad for all three items. I want to use the blower to blow off the new mower when I am done mowing. These came with the wrong charger so I took them back to Lowe's for a refund. I ordered a Pole saw. A two speed blower with no battery.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 09-11-18 at 12:38 PM.. |
