Old 12-21-15, 08:40 AM   #491
The work on the cooler/greenhouse continues. I worked on the boxing. This is time consuming each layer square needs to be custom cut. It kind of completes the envelope.
Everything I do to it lately makes it look worse but as you guys know it is all for the better.
ID:	6417   Click image for larger version
Old 12-21-15, 09:39 AM   #492
Wow, you're really going all out on this. Its not pretty, but it should really get the job done. Excellent work!
Old 12-21-15, 12:14 PM   #493
Thanks and I debated on if this step was needed. I have some of the reclaimed insulation left. I what drums of water to heat the greenhouse so I want to give it the best shot at it I can. If I was paying someone by the hour I don’t think I would add this step but it would bug me if I did not do it knowing the insulation to do it will probably just get tossed out.
Old 12-21-15, 07:00 PM   #494
I finished the boxing insulation tonight. I got out the night lights to finish it up. It was warm out and it is going to rain tonight and next day or two.
The cleanup crew came in to help out.
I am very happy and thankful that I had enough reclaimed insulation to put three layers on the greenhouse. I have a little left over to do my new dog house put a layer under the first row 55 gallon drums.
I saved so much money with this reclaimed lumber and insulation. It was such a great find.
ID:	6419   Click image for larger version
ID:	6420   Click image for larger version
Daox (12-21-15)
Old 12-21-15, 10:57 PM   #495
Here is a great write up on DIY Principles for a Passive Solar Greenhouse.
It is by Cord that designs and builds Passive Solar Greenhouses.
His designs is mostly what my greenhouse design is based on.
DIY Principles for a Passive Solar Greenhouse - Farm and Garden - GRIT Magazine
Old 12-22-15, 08:34 AM   #496
Insulation is done. I will need to come back and put up the rest of the 1 x 4 ‘s nailers. For now moving on to marking out the cement footers for the pallet racking cutting insulation for the first row of 55 gallon drums. After the cement and the first row barrels I will probably start on the vents.
This mild winter so far has helped so much.
ID:	6426   Click image for larger version
Old 12-22-15, 07:19 PM   #497
The first four barrels are in and full of water. Just a couple of solar batteries but more to come. I filled them with warm water about 100 degrees.
I put some Clorox in each barrel and left a little space for expansion.
Old 12-23-15, 09:38 AM   #498
It is raining outside but the greenhouse progress must continue.
I dug the footers for the pallet racking. Once I put in the cement I can add the next 4 barrels.
I cut up the rebar for the holes and bought the cement.
I cut some T post in ½ and pounded the half into the holes so just 6” was still showing.
ID:	6431   Click image for larger version
Old 12-24-15, 05:40 PM   #499
It did not rain the whole day so I made some progress. I was going to try and mix the cement but the holes kept filling back up with water. Maybe Saturday for the cement.
I finished putting the nailers on the back wall and put some more on the side walls.
ID:	6433   Click image for larger version
Old 12-25-15, 05:31 PM   #500
Last night my wife wanted me out of the house to wrap gifts. So I went out with a LED lantern and finished up the nailers.
One step closer. I am sure my neighbors thought I was crazy.
ID:	6435   Click image for larger version
