11-23-12, 01:55 PM | #1 |
Circulation pump: 2-speed, 4-wire
My new condensing boiler has a 2-speed circulation pump and I'd like to be able to control it even when the burner is not running. The pump has 4 wires coming out of it, all of them are the same color so I'll just number them 1-4. I checked that wire #1 is shorted to the neutral input of the power plug, while #4 has the standard live voltage (230V AC) when the pump is on. The other two wires, #2 and #3, both have slightly lower voltage, just under 200V.
Could anyone explain how the 4 wires are used to power the pump? And if and how I can make it run, either at low or high speed?
11-29-12, 07:25 PM | #2 |
Can you tell us what the boiler make and model is? Pump as well.
12-02-12, 02:47 PM | #3 | ||
As for the pump, all I can see on it is a sticker with the following: Quote:
12-02-12, 08:16 PM | #4 |
No name on it......
12-03-12, 12:05 AM | #5 |
Not that I can see
12-03-12, 05:21 AM | #6 |
Ariston is an Italian boiler IIRC so there is no telling what the make is. That said, 4 wires to any motor shows speed control. power, neutral and two signal wires. Within the enclosure there may not need to be an earth if it is connected through the body. Does the 200v signal ever change to another voltage?
12-03-12, 10:00 AM | #7 |
As far as I've noticed, it's the same ~200V on both signal wires whether in high or low speed. I'll try to check it again this evening.
I wonder what would happen if I just shorted the power pin to 230V AC, but not to the two signal pins? I'm kind of afraid of burning something up...
12-03-12, 07:22 PM | #8 |
Do you use the instantaneous DHW function or an external tank? If you use the tankless DHW, the pump automatically goes to high speed when there is a call for hot water, otherwise its speed is determined by the settings for the heat load of the house. I know that my Viessmann boiler runs at about 80% of max partly because of the weather compensation curve that was set. When DHW is called for, up it goes to high speed.
My guess is that if you mess with the pump control you will open a big can of worms because it assumes a certain pump speed to guide the fan speed which guides the gas valve. I cannot see anywhere in the service manual that you can have complete control over the pump. Sorry. |
12-04-12, 12:18 AM | #9 |
The boiler is for central heating only, DHW is from a different source.
The boiler's settings allow the pump to continue running after boiler has been called to shut off (by the room t-stat). The duration can be anything between 0-15 minutes or on all the time. It turns out that 15 minutes is too short in my case, while running it nonstop would be a waste, hence why I'd like to be able to extend the pump's run time. Maybe an option would be to set it to run nonstop and cut the power when it is no longer needed? EDIT: I checked the voltages between input wires and here is what I got (#1 is neutral, #4 is live 240V AC, #2 & #3 are signal): Low speed:
Ecorenovation - the bottomless piggy bank that tries to tame the energy hog. Last edited by Piwoslaw; 12-04-12 at 03:03 AM.. |
12-04-12, 05:29 AM | #10 | |
If you set it to run all the time, it should shut down normally on warm weather shut down so summer should not be an issue. You can put a "time delay relay" that will make contact when the t-stat calls but break contact when you choose, to a point. Time Delay Relays & Timing Modules - Datasheets - TE There is a good rundown here. |
