Old 03-07-14, 10:17 AM   #1
Boris romanov
Banned
Default Solar Panels Pose Challenges For Firefighters
On March 06, 2014 CBS broadcasted this report/video:
Solar Panels Pose Challenges For Firefighters « CBS New York
And similar info was posted here:
The roof is on fire: Do solar panels hinder firefighters? | MNN - Mother Nature Network
Probably, rooftop location of solar panels is not a safest option for the homeowners too.
Boris Romanov
Boris romanov is offline   Reply With Quote
Old 03-07-14, 11:15 AM   #2
ecomodded
Fortunately the fire department can adapt to each and every fire, they all provide different challenges. one example that comes to mind is Skyscrapers a much more challenging and hazardous situation.
I will add we pay fireman handsomely for their "service" my little city of 18,000 pays a big bag of money for.
Fire Department fire chief Tim Pley, with a base salary of $109,074.30 and benefits of $2,826.49, for a total of $111,900.79. He was followed by deputy fire chief Chris Jancowski, who earned $101,802.20 and received $8,491.72 worth of benefits, for a total of $110,293.92.
Chief fire prevention officer Randy Thoen earned $89,355.38 and received benefits worth $7,007.77, for a total of $96,363.15.
Meanwhile, fire captains Peter Aspinall, Edgar Francoeur, Herbert Nadig and Leslie Norden earned a total of $354,156.26 and received a total of $41,608.77 in benefits.
The remaining 12 firefighters earned a total of $880,111.39 and received a total of $92,587,92 in benefits.
The department has 23 firefighters in total, including Pley.
Total 1.6 million dollars for 1 fire every couple of years in which they tear the building down after they have finished.. now that's money well spent !! a Volunteer department can do that for about $50,000-$100,000 a year.
I hope I here no more sniveling about solar panels from the Fire departments, ridiculous.
Old 03-07-14, 01:39 PM   #3
Boris romanov
Banned
Originally Posted by ecomodded View Post
...Total 1.6 million dollars for 1 fire every couple of years in which they tear the building down after they have finished.. now that's money well spent !! a Volunteer department can do that for about $50,000-$100,000 a year...
Very impressive data.
Nevertheless, there are some additional health concerns similar to this:
"...Putting solar panels on the roof of one’s home, business or school is a good way to
provide an alternative to polluting conventional power plants. However, people
with electromagnetic hypersensitivity may not even be able to enter or be around
such a building. Since some of the milder symptoms of this syndrome are
common and non-specific, such as headaches and restlessness, a person using the
building may not even know his or her symptoms are caused by the solar system
...It is easy to demonstrate that the solar system generates dirty electricity. One
method is to take a simple AM radio, set the dial at the lowest frequency and hold
the radio near the solar panels or wires. A lot of static and buzzing should be
heard, which goes away when taking the radio well away from the building..."
http://www.eiwellspring.org/SolarEMFHazard.pdf
Proper locations of inverter and battery system are questionable too.
Boris Romanov
Old 03-07-14, 02:18 PM   #4
pinballlooking
pinballlooking's Avatar
Yes I agree my chickens do the chicken dance when I make max power each day.
They just know dirty power is their favorite kind.
I think this solar caused this chicken hawk to… sing
There are places that are requiring fire access around the array. A setback distance.
Where I am they don’t even inspect the array and they do not even require a building permit.
Old 03-07-14, 03:12 PM   #5
ecomodded
Boris these people you speak of, the hypersensitive ones, get "sick" from a cellphone or headaches from a toaster so i think your point here is moot, regarded as potentially debatable, but no longer practically applicable. Although the idea may still be worth debating and exploring academically, and such discussion may be useful for addressing similar issues in the future, the idea has been rendered irrelevant for the present issue..
Old 03-07-14, 03:33 PM   #6
Boris romanov
Banned
ecomodded,
I strongly disagree with you. There are no doubts - a continuous-wave radio frequency radiation is unhealthy issue in general and especially for young children.
To avoid endless discussions - just one example - the World Health Organization classifies cell phone radiation as Class B Carcinogen.
Boris Romanov
Old 03-07-14, 03:46 PM   #7
ecomodded
Its my understanding that low voltage/amperage is harmless.
Well if you hope to enlighten me , explain to me how much electrical radiation is being radiated from these solar panels into peoples houses as your interference with the am radio held close to the array is weak at best and who gives a rats azz at worst, unless your heavily into am radio.
assume the houses roof is 100% covered with solar panels to the tune of 10,000 watts which is a very large array to stick on your roof.
Old 03-07-14, 04:02 PM   #8
ecomodded
Oddly enough giving my stance, I have a electrical radiation detector ( a ELF meter) with digital readout coming in the mail as i type so I can investigate this very issue with the Power transmission lines that pass over some residences heads.
The voltage of the majority of transmission lines are in the range of 85,000 volts to 550,000 volts assume the amperage to be massive !
Old 03-07-14, 04:07 PM   #9
stevehull
Steve Hull
I believe that this discussion needs to be moved to the billiards room.
Steve
Old 03-07-14, 04:25 PM   #10
ecomodded
it is relevant to solar installations , but is also easily a topic to discuss over in the billiards room as it borders on entertainment and politics.
rooftop solar panels
