Old 11-21-16, 11:14 AM   #1
Default Dehumidifier repair
Over the weekend I acquired a new to me dehumidifier. A friend had recently replaced this one with another since it stopped working and asked if I wanted it. He knew that my old one had taken a dump and I was considering replacing mine. So, after checking that I could get parts for it still, I accepted his offer.
Here is the unit:
I was very happy to see it is a lot more efficient than the current old one that I am running. The old one is rated for 1.15 liters per kwh where as this one is rated for 1.8 liters per kwh, a huge 56% increase in efficiency.
So, I tested the unit by plugging it in. It turned on and the fan kicked on right away. I was able to mess with it and it seemed to be working correctly. I turned down the humidity rating below what the room was at, and the compressor kicked on. So, I'm wondering what the heck is the problem? It seems to work just fine. Well, after about a minute of running, it just dies. Everything goes blank on it. It won't power on at all.
So, next step is the tear down. I moved it into the other room, plugged it in, again nothing. I removed the panels, and then tried plugging it in again and it powers back up. Odd. So, now I start wiggling wires. It now cuts in and out, so I know I have a short. Woohoo, those are pretty easy to fix!
So, I start wiggling more wires until I can hear the zap-zap sound consistently when I wiggle it. It seems to be coming from a component on the circuit board.
Lastly, I flipped the board upside down, turned the lights off and wiggled things again. Now it was super obvious where the issue was.
I heated up the soldering iron, put some flux on it, and fixed the bad joint. I plugged it in and it seemed to work just fine. The compressor ran for a while without kicking out and it ran all night in my basement.
So, this was a great find and an easy fix!
I do have a few concerns I could use some help with though. First, the solder on the board did not melt easily. I did end up adding more solder to the joint and the two did not seem to mix well. I'm a bit concerned about the integrity of the repaired joint.
Second, the dehumidifier seems to run the fan continuously. This does not seem right. It is energy star rated so I assume it would shut the fan off when its not needed. However, as soon as you plug this thing in the fan immediately kicks on. When I went to check it out this morning, it was still blowing. I didn't check to see if the compressor was on or not. I unplugged it because it didn't even need to be running in the first place, I just wanted to make sure it wouldn't die on me overnight.
Thoughts?
ID:	7410   Click image for larger version
ID:	7411   Click image for larger version
ID:	7412   Click image for larger version
ID:	7413   Click image for larger version
