Old 08-27-12, 02:23 PM   #1
Default Necessity of a water hammer arrestor?
I replaced the kitchen faucet at my grandmothers last night. The new faucet must turn the water on/off faster, or have a higher flow rate than the last one because the water hammer effect is fairly bad. It moves the copper pipes in the basement around 1/2". I know this isn't good an the pipes will eventually fatigue and spring a leak somewhere. I'm thinking the best way to fix this is to add a water hammer arrestor? I know what they are and what they do, but I've never put one in or if there are other options.
Old 08-27-12, 03:47 PM   #2
LOL! Tell her to turn off the water very slowly..
I've used water hammer suppressors that looked like small versions of expansion tanks.
0269503 - Watts 0269503 - 150A, 1/2" Water Hammer Arrestor
Sadly, they only lasted a few years before the rubber disc wore out and leaked.
Can't really recommend them.
I went with a DIY air-pocket unit using 3/4" pipe. But, I placed the pipe very near where the water comes into the house.
Kinda like this..
I've used short air-pockets before and sometimes they fill up with water (to the top).
So, my 3/4" air pocket is about 6 feet tall.. It's never filled up yet..
If you decide to add some, I think at the end of a long run without bends is the best place.
(Mine is at the end of the long 3/4" run from the street).
If you can use a gentle turn, instead of a sharp 90deg turn into the air pocket, it will work better.
Like using a couple of 45deg elbows, instead of one 90deg elbow.
Old 08-27-12, 07:01 PM   #3
hamsterpower
+1 for the Xringer's suggestion.
Also where the pipes are moving add more brackets to secure the pipe. Straps or brackets every couple feet.
hamsterpower is offline   Reply With Quote
