08-12-16, 04:42 PM | #51 |
Wyr,
If a Leaf came along at an attractive price I might consider one myself. Especially used because someone else has already absorbed the high overhead. Also it sounds like you haven't expected more from the car than it can deliver. I think a lot of people make that mistake. Good luck with your Leaf, I'll bet you have a ball with it! Rob |
08-12-16, 06:08 PM | #52 |
It is an in town only car . At least in our part of the world . No DCFC in our area . Closest is about 125 miles away & it is a Tesla Super Charger . Which does me no good .
I am not trying to save the world by driving an EV . More of a whim . Probably an expensive whim . I am semi retired right now & drive a company truck , at $ 0 to me . I hope to work another year , at least before I fully retire & loose the company truck . I probably should have waited at least another year before I bought a 2nd car . Just got new tires on the Leaf . I like the way it rides & drives . We installed a Level 2 240 VAC EVSE & charging has been fine . 2012 Chevrolet Volt Premium - $11,978 - Mileage: 48,099 miles This was an email alert I received today . More $$$ and more miles than our Leaf . But more flexible in where you can go and what you can do . https://www.cargurus.com/ This is just one of several car search web sites . Try a search for Volts and a search for Leafs . God bless Wyr |
08-12-16, 10:04 PM | #53 | |
The miles per charge also went down on my Leaf when I installed the Ecopia's. It went back up after a 150 miles or so. I babied mine and got 50,000 miles on my first set. I run 42 psi in mine from when I acquired the car with only 950 miles on it. |
08-13-16, 02:16 AM | #54 |
Back 2 tires mounted earlier this week . I aired all 4 up to 42 - 44 psi . We will see what we will see .
Thanks , :-) Wyr God bless |
08-14-16, 10:25 AM | #55 |
Received my first full 30 day electric bill since started charging the leaf on a regular basis ( Level 2 ) .
Comparing it to same time period 2015 , the 2016 bill is about $ 80 something higher . Of course , this can vary some what according to Outside Air Temperature and how much I run the A/C . But bottom line , I am somewhat disappointed . We have been running our 2015 Chevy Sonic , mostly in town , on roughly $ 2 gasoline . Typically we would fill it up for less than $ 20 a week . This means , it appears , it is costing slightly more to run the Leaf on electricity than compared to the Sonic on gasoline . I realize , if gas goes up & I expect it to sooner or latter , those numbers will change . God bless Wyr |
08-14-16, 03:34 PM | #56 |
Go another month or two. How many miles on the Leaf for the month.
08-14-16, 04:27 PM | #57 |
Well , I reset the trip odometer shortly after we received delivery on the Leaf . Showing 1049 miles . Shows 4.1 miles per kw .
The guess o meter was showing 61 miles ECO mode after a full charge , a little while ago . GOM numbers have still not recovered since installing 4 new Bridgestone Ecopia 422 tires . Hope that changes in the near future . God bless Wyr |
08-14-16, 08:06 PM | #58 |
With monthly 1049 miles and 4.1 miles/kWhr, that sounds like you used about 250 kWhr/month. At $.10/kWhr, that would be about $25/month. Not bad for a month of driving . . . .
That is just about one fill up (gasoline) for the Chevy Sonic per week. Steve
consulting on geothermal heating/cooling & rational energy use since 1990 Last edited by stevehull; 08-14-16 at 08:26 PM.. Reason: clarity |
08-14-16, 08:22 PM | #59 |
I think the Sonic holds 12 gallons , more or less . But it was usually not empty .
If you figure the electricity that way , probably between $ 25 - $ 30 of electricity . Considering the whole charging & motor process is not 100% efficient . Figured that way , maybe some where between 1 & 2 weeks on the Sonic ? ( It only has a 1.8 liter 4 cylinder & 6 speed automatic . ) $ 2 gasoline makes it harder for the EV's to shine . Still hoping the projected miles per charge on the Guess O Meter starts to come up , as the 4 new tires break in . God bless Wyr |
08-14-16, 09:03 PM | #60 | |
I drive a company truck at work and to and from work . No cost to me . So , charging at work is a non issue . Although , I could easily run a 120 VAC circuit & exterior receptacle to do Level 1 120 VAC charging . Wifey is the person driving the Leaf . She is fully retired , so charging at work is again a non issue . With the old OEM worn tires I was getting high 70's miles per charge . Occasionally low 80's . The new tires are showing in the 60's . I hope that comes back up , as the tires break in . Range will surely drop , come winter , running electric resistance heat . Although it has electric heated steering wheel & seats . Said to allow you to run the cabin temperature lower , somewhat conserving some electricity . Latter Leafs have heat pumps as an option . God bless Wyr |
