03-31-14, 12:35 PM | #11 |
"It means the suction pressure going too high and the vapor getting too dense for the compressor design." Thanks for answer.
How would I know if it's getting close to this? Monitor compressor current? Am going to have a TMV set @ 90*F Max. for source water from solar tank to evaporator. Solar tank minimum may go down to 35*F, so 35* -> 90* for source. I think that I can figure out a way to have boiler run temperature up to 140*F every few days. Last edited by buffalobillpatrick; 03-31-14 at 12:39 PM.. |
03-31-14, 01:24 PM | #12 |
Just check if the compressor current is starting to go over the rated full load current.
The Following User Says Thank You to NiHaoMike For This Useful Post: | buffalobillpatrick (04-14-14) |
