Old 02-03-11, 04:57 PM   #321
wdrzal
That don't look so bad of a spot. Some nitrogen and soapy water will confirm the leaky spot. You do need to use a purge gas while brazing anyhow. A inspection mirror works wonders too see completly around tubes in tight spots. If it is a rub through from the vibration of that poorly mounted sensor you can flow some non-silver bearing brazing rod to patch a pin hole. Silver bearing flow out to much. Clean surface and no flux needed just copper/phosphorus rods,they do this nicely. But their liquidus temperature is over 1700f to 1800f so a two gas torch works best. Propane/O2.........mapp/O2.......Acetylene/O2. If a rod melts but the repair looks gooby or didn't flow you only got to the rods solidus temperature.
Somehow I knew you had a pic.
wdrzal is offline   Reply With Quote
Old 02-16-11, 11:39 AM   #322
pachai
Renovator-in-planning
Reading about these mini-splits, I wonder...Have any of you looked at a mini-split to figure out if it could be adapted as a water source?
Also, when it says Dual Zone, is that a hard limit, or is that as shipped? Do these things support buying additional inside modules - for example, if I need many zones that have a lower demand?
For my purposes, this would mean I could install a heating system in March and dig my ground loops in the May and June.
Ironically, I asked some Geothermal installers, and several just said
they could not even do vertical bores at my house. So I am going to try a hybrid - have the backhoe open a trench, and drill ala AC_Hacker.
By the way, is this a good calculation:
My boiler is rated for 187,500 BTU/hr.
It is on 1/10 of each hour....so, about 19,000 BTU/hr, i.e.,
2 tons.
Thanks
Seth
pachai is offline   Reply With Quote
Old 02-16-11, 11:44 AM   #323
pachai
Originally Posted by pachai View Post
Have any of you looked at a mini-split to figure out if it could be adapted as a water source?Seth
I mean, instead of starting with a retired window air conditioner, start instead with a working reversible heat pump. Like an aftermarket hybrid school bus, the pump won't need to know WHY it is so easy to pump....
Thanks
Seth
Old 02-16-11, 12:44 PM   #324
I was thinking of a non-attached (open-loop) water mod for my Sanyo.
Drill two wells and install a water-to-air exchanger behind the Sanyo,
so most of the air pulled into the Sanyo has to pass through it.
It would be great on those hot summer days, since I could use PV for the water pump.
It would have to be self-draining, so no water would stay inside any of the plumbing,
when the power was off.
The ground water here is 60-65 degrees F. So, I think it would do good
during the summer, and might even be good when it's really cold too.
But, I don't know if a low dew-point and high humidity on cold days
would ice-up the A-W exchanger.. Maybe the right amount of 'warm'
water flow will keep the plumbing so warm, it will just drip off and not
build up an ice-cake.. It would need to be adjustable.
Old 02-20-11, 09:28 AM   #325
Default plastic bag crash
Last night, it was about 15F with 50% humidity, we suddenly had power-overload alarms.
This normally happens if we call for a too-big increase in temp, (which we did not do),
or right after a defrost cycle, when the firmware issues a too-big increase.
I was 99% sure there was no ice on the outdoor coil, but I got my little LED flashlight and checked it out..
No frost, but there was a plastic bag.. A CVS bag was blocking the air input on the bottom of the coil.
It was only covering about a 10"x10" area, but it seems to have been the cause of the over-current.
(Line voltage was normal at 242vac).
So, if you have a heat pump running and live in the city, watch out for plastic bags! (And leaves in the fall)..
Old 02-25-11, 10:08 PM   #326
Here's two more pics..
I've been thinking about this for a while.. But while it's so cold, I'm delaying trying to find the leak..
I have a buddy that has some portable torch equipment. He might be able to give me a hand, once I find the hole..
Old 02-28-11, 10:42 AM   #327
Default T-Run
In this pdf, on pages 51 & 52, they show a T-Run socket.
http://us.sanyo.com/dynamic/LinkList...sion%204-1.pdf
It's the white socket shown in the center of this pic..
The T-Run (Test Run) pin seems to allow the Sanyo to run, without an indoor unit attached. (Electronically).
It can also be used for Pump-down. (Removing the R410A from the lineset).
So, it makes me wonder if one could use the outdoor unit with different type of heat exchanger inside the house.?.
Perhaps a hot water heater??
I'm thinking about this stuff, because I have a spare outdoor unit in my garage.
Once repaired, it might be usable for all sorts of things..
If the T-Run doesn't time out in 2 minutes..
Old 02-28-11, 11:09 AM   #328
I don't see why not...
Old 02-28-11, 11:21 AM   #329
I was just thinking. If I hauled that outdoor unit down to my basement and ran a line-set loop outdoors,
to a heat exchanger down in a well (sitting in 50 deg water).?.
Maybe I could heat my Basement?
Or dehumidify & cool it during the summer?
Old 02-28-11, 02:30 PM   #330
pachai
XRinger,
That's along the lines I was thinking.
Take a really efficient ASHP and upgrade
it for a fraction of what a commercial GSHP
or WSHP would cost. Looking forward to
hearing if you try it before I get to that stage.
air conditioner, diy, heat pump
