Old 01-24-10, 04:03 AM   #1
Default Solar cells vs extreme cold
I got a solar flashlight from Santa this Christmas, and the last two days saw the first rays of sun since then, so I put it out the window. The temperature was quite low (-15*C, 5*F), but at least the sun was shining When I it got dark I brought it back home and noticed "bubbles" on one edge of a few of the solar cells:
These didn't go away after a night in the warmth. Today is even colder (it was -25*C/-13*F this morning), so I decided to keep the flashlight indoors.
Could the extreme cold have caused the lamination to separate from the cells? I have an old AA battery solar charger (the top of a solar garden lamp) that's pretty beat up: the lamination is cracked and seems to be separating. This charger has been in the sun in extreme cold and heat, has been tied to my backpack while hiking and tied to a kayak during a water trip, so I'm not sure whether its state is caused by temperature alone.
Does anyone know how temperature can effect solar cells?
ID:	600   Click image for larger version
Old 01-24-10, 04:21 PM   #2
It's not a problem with the cell it's self it's a problem with the cheap epoxy that was used to encase the cells, solar cells like the cold and are not hurt by the cold, as long as it's not blocking the sun from getting to the cells and that air is not getting to the electrical connections you should be fine.
