Old 07-22-16, 05:05 AM   #21
WyrTwister
On both of our MS's , I used an old Craftsman flare tool that I have had 35 - 40 years . I obsessed over the angle , so I did a trial fit . I came to the conclusion , is coated inside and outside with Nylog Blue , the copper tubing is soft enough that that it will conform to the angle of the flare fittings .
The expansion device is inside the outside MS unit . In A/C mode , the refrigerant will flash and cause the line to frost , if given a chance ( low pressure area ) . If you are low on refrigerant , you will have low pressure on the suction side of the system .
Would be best not to run it low on refrigerant . This is my opinion , others may disagree .
A small oil loss is probably not a problem ( a few drops ? ) . The outdoor units come with enough oil for the max allowable line set . How long are your lines , compared to that number ?
I use UV dye on automotive applications . And the little UV flashlight . If in doubt , add a little when you add refrigerant .
Put your gauges on and check the pressures ( after your refrigerant arrives ) . Run it briefly & check to see what the pressure is at the suction side . As long as it has some positive pressure , running , no air / moisture could have gotten into the system .
I would leave it with a few pounds of positive pressure & weigh the amount of refrigerant added , according to factory data . If you can , add it as liquid . R410a is a mix of at least 2 refrigerants of slightly different boiling points . If you add refrigerant as a gas , constantly shake the refrigerant tank to keep the vapor mixed .
Best I remember , you did a self install ? You gained the knowledge base to do a repair , now . :-)
God bless
Wyr
Old 07-22-16, 03:22 PM   #22
Thanks. Yes I did my own install with the help and advice of others on this forum.
Good news is I did the repair about 5 weeks ago and it is still running nice and cold.
It really has been put to the test as it has been very hot lately.
Old 07-23-16, 06:10 AM   #23
I have had good success with the flare tool kits from the local auto parts stores as well. If someone was really not wanting to spend the money on a tool to keep forever, they are available on the "loan-a-tool" program. I believe the deposit is somewhere around $75. Pay deposit, get the set, do the work, return the set for and get your deposit back. Those sets also do the "double flares" which are a little more forgiving and mechanically tougher.
A tip for the less experienced: before you bend the tube, double check that you have the correct flare nut installed. Without it, you will be cutting off that brand new flare and doing it all over again. If you forget, you have my permission to curse loudly.
Old 09-07-16, 11:30 AM   #24
WyrTwister
I use Nylog Blue on both sides of the flare & nut .
This seems to make it easier for the soft copper tube to conform to the shape of the flare .
God bless
Wyr
Old 09-24-16, 12:55 PM   #25
Default 45 degrees!
Just saw a video.. R410A M/S units require 45 degree flares.. Here's the proof!
https://youtu.be/JI1ckYDi2WM?t=53s
I hope!
Old 06-18-17, 01:12 PM   #26
My repaired mini split is still running good. I ran across this video that would have helped me trouble shoot my mini split at the time of the issue.
Old 07-24-17, 02:45 PM   #27
Just One More
Just One More's Avatar
Great thread PBL.... Very good info.
Just One More is offline   Reply With Quote
