#1 |
![]() Its a work in progress, but I started compiling a list of whole house fans and their specs and efficiency ratings in CFM/watt. Oddly enough, they're all over the board. The list is still growing, so I'll just post what I have so far. It appears the smaller Air King whole house window fan is really a great deal and a pretty efficient fan. The price varys widely as well. This is mainly due to some fans having active/insulated dampers and others just being a fan in a steel frame.
If anyone knows of any whole house fan manufacturers not on the list please let me know and I'll add their products.
#2 |
![]() CFM/Watt is a fan efficacy quotient I've seen before, but it's a strange one. Flow * Pressure = Energy, so 1 CFM * 1 PSI = 3.25 Watt. If all the fans are tested with the same backpressure, then the efficacy rating corresponds to the thermodynamic efficiency of the fan as an air pump. However, this is a case where efficiency might not be a good measure of how cool it keeps you.
As for the dBA ratings... well, ask any SilentPCReview reader, and he'll point out that if you put the microphone near or far enough to the product, you can get any dBA rating you want. I really wish there were pervasive standards out there, such as all testing being done in a room of a certain geometry, with the microphone 1m away from the sound source. EnergyStar has compiled a list of ventilating fans: http://downloads.energystar.gov/bi/q..._prod_list.pdf It's also available in .xls for your sorting & filtering convenience. ![]() |
#3 |
![]() Do you have any suggestions on how to rate the efficiency of the fans?
I looked at that list, and I see no whole house fans capable of exhausting the volumes of air I'm looking for (2000+ CFM).
#4 | |
![]() Hmm, here is what the EnergyStar website has to say about whole house fans:
So, does this mean all fan designs have roughly the same efficiency? Should I not worry about power consumption and just find one that blows enough air and be done with it? I know energystar isn't the end all in efficiency, but they have a decent handle on things. I still find it hard to believe all fans are basically the same.
Current project - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Daox; 06-09-11 at 09:24 AM.. |
#5 | |
![]() Quote:
I'm not sure if blade fans like whole house fans have any design considerations or more efficient motors than others. I don't think that 200 or less watts is very much at all when comparing running an air conditioner instead. I had abandoned the thought of installing a whole house attic fan until I read that there are insulated ones in this thread but probably still won't because in the hot summer season when I would use it, the nights are very humid and I'd need to remove that humidity with the air conditioner during the day and use more overall power keeping it colder to make it more comfortable than if it were warmer with less humidity. ..stuff to consider depending on where you live. |
