Old 01-23-13, 06:26 AM   #11
Mikesolar
Mikesolar's Avatar
here is another one from Honeywell, about $180 US for both valve and motor IIRC
Old 01-28-13, 11:46 PM   #12
SolarUtah
Cheap Renovator
I buy alot from Kele. They sell all kinds of valves. Kele | Control Valves
Good guys to work with. Or you can try and find one on Ebay. Sometimes there are good deals there.
You will need a 24 volt AC power supply, best to use a 0-10 volt signal.
Good Luck!
SolarUtah is offline   Reply With Quote
The Following User Says Thank You to SolarUtah For This Useful Post:
buffalobillpatrick (04-04-14)
gas, mixing valve, solar
