Old 03-16-09, 09:57 AM   #71
jwxr7
jwxr7's Avatar
Changed the array's angle over the weekend finally. It's now at 40 degrees, optimised for spring/fall sun. I noticed better power into the evening compared to the evening before the angle change with similarly sunny days.
When I originally built it, I didn't built with spring summer angles in mind (for some wierd reason) so I had to add support in the middle of the array to keep it from sagging .
Old 03-16-09, 10:06 AM   #72
It looks pretty good. How have your numbers been lately?
Old 03-16-09, 10:29 AM   #73
jwxr7
jwxr7's Avatar
They were pretty bad until late last week when the sun started shining again. I had 2 record days in a row over the weekend. I'll post some #s soon.
Old 03-17-09, 08:06 AM   #74
jwxr7
jwxr7's Avatar
Here are production #s from Feb 25thru march 16 2009;
February 25=520whrs
26=500
27=200
28=1360
march 1=640
2=1320
3=1320
4=1380
5=500
6=1100
7=20
8=20
9=180
10=20
11=820
12=880
13=1410
14=1460
15=1300
16=1280
Someday I should graph my #s .
Old 03-17-09, 09:25 AM   #75
Interesting sway in numbers, really bad from the 7th to 10th, then really awesome from 13th+.
Old 04-16-09, 08:00 AM   #76
jwxr7
jwxr7's Avatar
Here are some monthly production #s.
For all but the first 6 days of january, 13.18 kwhrs (the array went on-line Jan 7th) averaged 549whrs/day.
For the 28 days of February, 20.42 kwhrs or an average of 729.3whrs/day.
For the month of March, 26.31 kwhrs or an average of 848.7whrs/day.
Old 04-16-09, 08:07 AM   #77
jwxr7
jwxr7's Avatar
I just noticed that in 4 days it will be time to change the angle of the array for summer already . I guess I better figure out what size legs to make. Maybe I can just move the bottom of the spring/fall legs to get the angle.
Old 04-16-09, 12:14 PM   #78
Not too horrible of a setup for free. Still any idea of what percentage of your total electric use that is?
Old 04-21-09, 09:51 AM   #79
jwxr7
jwxr7's Avatar
I just checked my last utility bill and averaged the last years electric consumption to 21.7kwhrs per day. So in a month I can make up 1 day's worth of consumption. What's that, like 3.3% or so?
Old 06-01-09, 07:29 AM   #80
jwxr7
jwxr7's Avatar
I had 2 different power outages in April. One was just long enough to erase the Kill-a-watt memory and the other lasted 25 hrs. So April production was 25.74 kwhrs, or about 919.3 whrs/day (using 28 days because of power outages).
On May 10 th I changed the array to the summer angle.
The month of May saw 32.88 kwhrs of production, or an average of 1061 whrs/ day.
I need to try modding my kill-a-watt to have battery back-up.
electric, solar
