Old 09-21-11, 02:08 PM   #951
kb1
Looks like it has a very tapered thread, so you'll need to come up with an adapter of some kind.
This is an API (American Petroleum Institute) thread. The folks over at practicalmachinist.com forum have more information. Google for "Anyone know about API (oilfield) threads?"
kb1 is offline   Reply With Quote
The Following User Says Thank You to kb1 For This Useful Post:
Geo NR Gee (09-22-11)
Old 09-27-11, 01:50 PM   #952
Geo NR Gee
Kb1,
I contacted a few folks over there at the Machinists site. Thanks for that. They mentioned it would be better to have a sub adapter made that would work for the tricone bit instead of making it myself.
After talking to a couple of machinists, they quoted me at $600 for the sub adapter. Thats not in Not in my budget. So, it looks like back to plan A. I will post pictures after its done.
Old 10-24-11, 12:35 PM   #953
Default Info Regarding R-290...
There is an interesting site called HVAC Talk that I read from time to time. In spite of the fact that they are generally DIY UN-FRIENDLY, useful information can be found mixed in with all forms of personal prejudice, so picking the useful from the useless is part of the challenge.
There is a thread regarding the use of R-290 (propane) as a refrigerant...
Most of the thread is filled with dire warnings of certain catastrophe, posted by people who obviously had no actual experience using R-290. Then this post appeared in the thread (picking the useful from the useless is still part of the challenge):
I sure wish you would stop the fear mongering, mythology etc about R290.
It is not going to launch your house to the moon!
It is much more efficient than the present garbage being pushed by big business an the EPA. Especially the EPA.
They are spitting out lie after lie to keep you hooked into their systems.
The auto ignition temperature is R290 is quite high making it a much safer gas to be around than gasoline but no one is afraid of gasoline!
I have been servicing my personal central air systems with R290 for over 30 years.
Yes I do check them for leaks with a torch and have found leaks this way.
Yup it lights off! Don't pee your pants just put it out. Usually I blow it out. Wow that was scarey.
Almost every country in the world uses R290 except the USA "GD EPA!"
I also use a blend of R290/R600A in my automobiles. Have been since the lunacy about R12 started. Go get um Dupont. Sell um more crap, "R134A."
Before I'll service my cars with R134A I'll drive with the windows down. That crap will kill you.
Benefits of R290 are due to the uni molecule and a better laminar flow in the tubes, higher heat transfer etc.
Even in old unit designed for R22 you will attain a savings in energy of approximately 20% by just replacing R22 with R290. With a new unit built for R290 you will save even more. First you save in initial cost as the tubing can be smaller, “costing less” the Compressor can be smaller due to the smaller loads, etc, etc, etc.
My house has two units. One is a split unit with the Condenser/Compressor unit on the ground and the Evaporator/Air Handler in the attic above the third floor.
The second unit is a Package 3.5 Ton Miller heat pump.
The Miller was charged with R22 when I purchased it on Ebay for $32.00.
I purchased a Foreclosure "highly vandalized" for setting up for retirement.
The copper had been stolen so fixed up the split unit with copper and wiring and charged it up with the last of my R22 stock. It ran fine did a great job for about three weeks.
I then started checking for leaks as it was not cooling very well. Pressure was down and I found a leak in the air handler.
Not wanting to be ripped off again by my government and Dupont I said to hell with it and dried some old fashioned propane from a 100 lb bottle into a 30 lb recovery bottle.
It's got to be dry! Real dry!
Propane/R290 is totally orderless so they add “Methanethiol (also known as methyl Mercaptan) is a colorless gas with a smell like rotten cabbage” so you can smell it.
I've heard it smells like the cabbage statement as well as rotten eggs. I don't think it smells like either of them.
Mercaptan is Sulfur based and will make Sulfuric Acid in contact with moisture.
Make it dry guys/gals.
I use two large dryers in series with my manifold when charging my service bottle.
Probably over kill but it works. I've never had any problems with years of using it in my systems.
Of course there are manufacturers who make compressors and other equipment designed for R290 which makes it even more efficient.
Smaller tubes as the uni molecule flows more efficiently than R22, “reducing the charge needed” therefore less product to move with the compressor thus saving energy.
Even with that as I stated if you just recharge your old R22 system properly with R290 you will gain an over all efficiency increase of about 20% to 30%. Personally I've never achieved more than 20% but at the cost of energy these days I'd do it for 2%!
The flammability of R290 is a none issue but I'll leave it to those of you with intelligence enough to do your research and find the truth yourselves. I'll leave the Myth spitting idiots to themselves and hope the hell they never work on any AC system for any of my family!
Ahh hell here is some info from research done in Australia.
They have made R134 illegal to import or use. They use R290 and R600a.
Look here for another source of info. Not EPA Obama propaganda.
Remember the words are sometimes not spelled the way we do. They speak real English, we speak a dialect that is made up from many languages. I too prefer our way of spelling etc, but don't want you to think idiots wrote this.
They are just as smart as us and a hell of a lot smarter than the idiots running our country.
7 Ignition Probability
Lunde and Lorentzen [19] found that a toxic refrigerant flammable in air but with an odour can have lower accident frequency and risk than a nontoxic, non flammable, odorless refrigerant. The presence of odour from a leak warns people to take appropriate precautions. Almost all R290/600a used in MACS is odorized and this may be partly responsible for there being no recorded injuries or over pressures (Table 3).
Most of the predicted fires in Table 3 were condenser leaks igniting following collisions. For example, [14] gave the frequency of leaks following collisions of 0.01 per car-year and multiplied this by a 0.01 conditional probability of ignition. Odour has no effect for most fire scenarios as occupants are in the cabin and the leak is in the engine bay.
A typical MACS leak is less than 1 mg s −1 which is too small to sustain a flame since the heat loss at flame temperature is greater than the heat generation rate [20].
Leaks up to 15 g s−1 peak have been measured from MACS [4] and are possible after collisions. While liquid R290/600a remains above −20 ◦ C, the pressure in the MACS will be over 189 kPa. The jet from most such leaks only slows below the flame velocity when it has mixed with air below the flammable limit. It is flammable only with a permanent ignition source [21]. Cars in normal operation have no exposed ignition sources for R290/600a [14] and permanent ignition sources are created in few collisions.
Fracture of the MACS liquid receiver or attached tubes in a collision can produce a leak rate up to 300 g s−1 [21] for less than 1 s. About 200 g of R290/600a liquid can flash to a 25 L white cloud. The cloud is initially about 7 times denser than air but is flammable only at its boundary. Normal atmospheric motion removes it from possible ignition sources in less than 2 s and dilutes it below flammable in less than 10 s. Only cases without ignition are known [15].
For the previous reasons, R290/600a is non flammable under the conditions of most leaks. This is consistent with the actual conditional probability of ignition being hundreds of Hydrocarbon ignition sources
Razmovski (1994) and Rajasekariah (1995) searched for ignition sources using
a propane welding torch attached to a cylinder of hydrocarbon refrigerant.
The car was parked in a sheltered outdoor position with fine weather.
They started the engine and allowed idling until it reached normal operating
temperature i.e., typically for ten minutes. They ignited the welding torch then adjusted it to give a stable yellow fame about 70 mm long. They extinguished the fame with an air blast and tested for easy re-ignition with lighted matches and cigarette lighter.
The extinguished torch was played over the hot engine, electrical, ignition and exhaust. Then the door, light and brake switches, fan motor, relays and cigarette lighter were tested in the passenger compartment. Each test took over fifteen minutes and 50 to 100 g of flammable refrigerant were used for each test depending on the car. Table 5 lists the model and year of manufacture of the ten cars. They found no ignition sources either inside or outside the passenger compartment on any of the cars tested.
Leakage of fuel into the passenger compartment is not uncommon. A manufacturer would be negligent to use open relays, switches or motors which could ignite a fuel/air mixture. Enclosed electrical components are also more reliable saving on warranty claims. The incidental effect is a match or cigarette lighter is the only ignition source for a refrigerant mixture in the passenger compartment as Razmovski and Rajasekariah found. The consumption of cigarettes over the whole driving population is equivalent to about ten cigarettes a day (Department of Community Services and Health 1990). I will assume that half the cigarettes consumed in cars are lit with the car’s cigarette lighter and would not cause ignition. We then have five potential ignitions per driver per day.
That's enough, go look for yourselves.
You can choose to believe the EPA if you wish.
I have had some very close up and personal contact and dealings with EPA!
They are Idiots with an IQ approximately the same as the square root of their shoe size!
...and also this post:
They are selling it here in Canada at our local Canadian tire (like a Home depot but they don't sell lumber) store under the brand R12a. It is propane with an evergreen oderant mix. You can use it for a replacement for R134a, and R12 without changing oil. They also have a replacement for R22.
This is the best part of this, ANYONE, can go in and buy these kits. Comes with a gauge and adapter for your system, and instructions on how much to put in.
Tells you if you smell the evergreen smell, to open all windows...(lol)
Best Regards,
The Following 3 Users Say Thank You to AC_Hacker For This Useful Post:
Daox (10-24-11), ThomSjay (10-26-11), Zwerius (01-06-16)
Old 10-26-11, 11:09 AM   #954
ThomSjay
Thanks for that A/C H! It kinda confirms my thinking.
TomS
ThomSjay is offline   Reply With Quote
Old 10-29-11, 06:00 PM   #955
hacknslash
Default Geo-Column... Direct exchange idea I found
I found this website with a direct exchange idea that I haven't seen posted here or anywhere else for that matter. It doesn't look like the company is building a product yet, but it might be simple enough that someone could put together something like it.
wwwDOTgeoenergyusaDOTcom/column.htm
Later
hacknslash
Oregon
hacknslash is offline   Reply With Quote
Old 10-29-11, 07:17 PM   #956
"The field model of the GeoColumn is a factory sealed and tested, rigid HDPE containment vessel that is 24 inches in inside diameter, 28 inches in outside diameter and 20 feet in overall length. This vessel contains a copper tube refrigerant gas heat exchanger submerged in pure, unconditioned water; thus it is a hybrid direct exchange system but with unique properties. "
GeoEnergy Enterprises
A few of those in my backyard would work fine. Since my ground water is very near the surface.
"One column is required per ton of conditioning in most soil conditions therefore an average home requiring 3 tons of heating and cooling capacity would require only 3 GeoColumns to be installed to allow access to geothermal efficiency and advantages."
Dang, I would need 4 columns, since I've got 4 tons of Sanyo running..
I guess maybe I'll stick to stealing the heat out of the air..
Old 10-29-11, 08:39 PM   #957
Default Questionable DIY Potential
Since this is a homemade heat pump thread, I feel obligated to look at this through that lens.
I find that this idea may be worth discussing, but not in a thread that is dedicated to DIY.
The web page that is referred to states:
...the GeoColumn can be installed with standard caisson or utility pole type drilling equipment...
Let's get honest folks, no one on this blog is going to fabricate caisson drilling equipment.
This thread is not for sci-fi, it is for things we can actually make or modify ourselves.
Old 10-29-11, 09:35 PM   #958
hacknslash
Getting rid of the parasitic pumping losses is really nice, but the more I look at the Geo Column, I'm not liking it.
It would probably work well for cooling a house in the summer.
But for heating, you would turn that container into an ice ball pretty quick and you'd eliminate the advantage of geothermal which is stable ground heat above the freezing point.
You might as well be using an Air source heatpump, unless you live in a really cold climate then maybe.
Old 10-29-11, 10:02 PM   #959
I looked at the column as something that could be scaled down to a DIYer size.
If you could use 20 foot pipes with a much smaller OD, (4"?) and connect a bunch of them parallel,
they might be useful in high water-table areas.. Like my backyard!
ATS Irrigation Aluminum Pipe
Edit:
I wonder what would cost more, digging slinky ditches 8 or 10 feet deep? Or drilling 15 or 20 holes.. 10"x20' ??
In the end, the ditches would likely be cheaper.
Plus, the added cost of building the 20 foot tubes wouldn't be worthwhile..
Old 11-02-11, 08:48 PM   #960
kbonk
Do you have a drawing of what you want? I might be able to do something
K
kbonk is offline   Reply With Quote
