11-09-11, 12:21 PM | #1 | |
Honda will be making hybrid snowblowers
Yup, you read right, hybrid snowblower. Sounds like either a commercial type machine or super luxury machine. I'm not sure what to think about this, but they're making them...
11-10-11, 09:13 AM | #2 |
okay, that is hilarious!
11-10-11, 12:42 PM | #3 |
Maybe it's more efficient or cheaper to have a small gas generator charging a battery and then an electric engine powering machine instead of a large gas engine directly connected?
I've often though cars with electric motors that are powered by a generator should be more efficient since the generator could be tuned to run in the perfect RPM range and a small battery bank could be used to carry things through when the generator falls a little bit short. |
11-10-11, 12:53 PM | #4 |
The torque from the electric motors driving the treads must come in handy too. Still. Seems like a bit of overkill. I have to confess my first thought was that maybe this was a joke ...
11-10-11, 06:20 PM | #5 |
Guest
Posts: n/a
Why not just make an electric snow blower with a battery warmer?
11-10-11, 08:16 PM | #6 |
I'm assuming the battery/weight ratio just isn't good enough to go pure electric.
11-11-11, 08:33 AM | #7 |
For those with shorter driveways apparently there are commercially sold corded snowblowers. If I had a short driveway I'd probably go that route.
I also know local guy here who just did a conversion on a gas blower to corded AC snowblower last year. He says it works great and the quiet is so much nicer than having a gas engine running.
12-26-11, 03:52 AM | #8 | |
It may be overkill, but that machine is built for a niche market where a ton os snow is the norm, primarily Canada and parts of Japan, where features like electric track drive and power chute control are worth the price. It's a whooole nother world. Adam |
