11-24-15, 04:17 AM | #1 |
Guest
Posts: n/a
Mini Split Heat Pump Mode
Turned it on a little ago . This is the first time I have used it , as opposed to playing with it .
Seems to give an even heat . Have the swing louvers pointed almost all the way down . Hopefully , the warm air will mix with the cold / cool air at the floor , before it rises ? Indoor unit is over the living room exterior door . Having a heat source , at that location , may help with any air leakage / drafts , around the door ? The internet indicates it is 41 degrees F , outside . Seems to be working OK at that temp ? When was the last time I mentioned how quiet it is ? God bless Wyr |
