05-14-14, 01:10 PM | #1 |
What tools are needed to work on / hack a heat pump?
What do I need to hack a heat pump? I think this is a common question most people would ask when jumping into the DIY heat pump game. I know I've asked it to myself when I was tinkering with fixing some water coolers, and I still don't fully know the answer. So, I figured I'd pose the question to the experts here on the forum.
So, what do you need to hack a heat pump? What is absolutely necessary? What is nice to have? What do you look for in a micron gauge or vacuum pump? Stuff like that. I think I'll probably compile the info here and write a blog post because I think it'll be very helpful to others.
Current project - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Daox; 05-14-14 at 01:18 PM.. |
05-14-14, 02:46 PM | #2 |
Not necessarily in that order. -AC
05-16-14, 02:43 PM | #3 |
Inert gas(dry nitrogen or welding argon)
Tubing bender Leak finding apparatus |
06-04-14, 10:53 AM | #4 |
Andy
Thermometer(s).
