Old 08-16-15, 02:19 AM   #21
NiHaoMike
NiHaoMike's Avatar
You can emulate the center channel by sending the signal to both speakers. Very easy to do in the analog domain (can be done with as little as 4 resistors) but not so easy in the digital domain (FPGA would be the easiest, which is not at all beginner friendly).
Old 08-19-15, 06:41 AM   #22
OffGridKindaGuy
Hi-Tech Hillbilly
OffGridKindaGuy's Avatar
Send a message via AIM to OffGridKindaGuy
I build 5 volt amps with Bluetooth. (3 watts/channel) Will run all day on a 5 volt bank battery. (5600 maH.) Impressive on some sensitive speakers..
If it don't, I'll always think it shoulda..
OffGridKindaGuy is offline   Reply With Quote
The Following User Says Thank You to OffGridKindaGuy For This Useful Post:
jeff5may (08-19-15)
Old 08-19-15, 08:45 AM   #23
OffGridKindaGuy
Hi-Tech Hillbilly
I also build my own Boom Boxes with these combos. Anyone wanna see some pics?
Old 08-19-15, 08:55 AM   #24
Put em in the thread where I won the badger solar panel.
Old 08-19-15, 09:00 AM   #25
OffGridKindaGuy
Hi-Tech Hillbilly
OK.. Will do tonight..
Perfect match for that systerm..
*They's over there..
