#1 |
I saw a listing on Market place angle iron they recovered from an old building.
It was listed for $5 and I bought it. It had a couple 1/4" 7' pieces and a few other smaller pieces. I have been needing a new cooling rack for powder coated parts. I used a couple old rotors from my Tahoe they are very heavy and will keep the rack from falling over when loading. The steps are 1/4" steel and take a while to cool. A lot of the other parts are 1/8" and cool much faster. I also built some more cooking racks with rebar and expanded metal. Now I have 4 places for parts to cool and 5 cooking racks. It is always fun to use stuff that would go to the landfill to make useful stuff. Keeping cost down always helps.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 06-07-21 at 04:50 PM.. |
#2 |
Great reuse of materials.
#3 |
My cooling rack holding at least 150 pounds no problem.
| Thread Tools | |
| Display Modes | |
