Old 07-02-18, 12:07 PM   #1
jjackstone
Default Electric vehicle battery age
I'm looking into Leaf or Volt battery packs for solar storage. I have a question. Is there a way to verify what the age is for a pack that has already been removed from a vehicle? Maybe stamped somewhere on the pack? I know state of charge is just as important as age. I just don't want someone to tell me they have a 2013 or 2014 pack and it actually turn out to be a 2011.
Thanks guys.
JJ
jjackstone is offline   Reply With Quote
Old 07-14-18, 03:15 PM   #2
jjackstone
Ok. No takers. Well, I got a pack and there is a plate at the business end(electrical connectors) of the pack that has a date that says 07-09-12. While it doesn't specifically say that is the build date, I'm going to guess that there is a good chance that it is. Haven't been able to find any information about this at any of my regular info forums or at any Volt forums. I'll post pix when I have more time.
JJ
The Following User Says Thank You to jjackstone For This Useful Post:
MetroMPG (07-23-18)
Old 07-16-18, 10:51 PM   #3
jjackstone
Name:	Circled date code.jpg
This one is the front end of the pack. The area circled in red has the date code. I am guessing that it is the build date, but it is actually stamped into the metal so it could just be the date the end plate was built.
Name:	Volt build date.jpg
Here is a close up.
JJ
MetroMPG (07-23-18)
Old 07-17-18, 08:48 AM   #4
pinballlooking
pinballlooking's Avatar
I would also bet it was the build date good find.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 07-23-18, 01:23 PM   #5
MetroMPG
Infrequent noob
What info did you get from the seller on the pack's condition?
Or is this a hope/prayer kind of transaction?
Old 07-23-18, 10:19 PM   #6
jjackstone
The seller had a 2014 Volt with a wrecked front end. He bought the 2013 model with a wrecked rear end to replace the front end on his vehicle. He said he used to work as an auto mechanic and from the vehicles he had in his yard I believe him. He also said that the Volt he bought must have been fully charged just before the accident since it showed a near full charge on the gauge. Also said he was able to drive it up on a ramp to facilitate the removal of the pack. I expect to pull the cover this week to at least test the voltage level.
JJ
Old 07-24-18, 04:05 PM   #7
jjackstone
Ok I couldn't wait. Pulled the cover off the pack and the meter reads 384 volts. That sounds like a win to me.
JJ
bidaw (08-10-18)
Old 08-10-18, 09:06 AM   #8
bidaw
JJ
Anxious to hear your story about how you will implement and use this pack!
Good Job!
bidaw is offline   Reply With Quote
