12-11-09, 04:37 PM | #11 | |
Regards, -AC_Hacker |
12-11-09, 05:17 PM | #12 | |
12-11-09, 07:50 PM | #13 |
I think a diode might not work at all and it might burn the motor up..
For a small AC pump, maybe a motor speed controller that was designed for AC motors? Big Horn 18852 Router Speed Control (19122) Years ago, I used one on the large blower on my wood stove. I could vary the RPMs from full speed to very slow. Last edited by Xringer; 12-11-09 at 07:52 PM.. Reason: url typo |
12-12-09, 01:32 PM | #14 |
The pump I have in mind is AC powered and pumps water through the furnace to the radiators (it's not for blowing air). I'll look for an AC motor speed controller.
Thanks |
12-12-09, 03:20 PM | #15 |
Before you shell out your money, better check what kind of AC motor the controller you might purchase, is compatible with.
Router motors are not induction motors, they are universal motors. Electric drills, routers, hand held grinders, etc are all universal motors. They all have brushes... look for the brushes. I have three AC water circulation pumps in my basement, and they are all AC Induction motors... no brushes, no easy way to control speed. Check this stuff out before you spend your money. Regards, -AC_Hacker |
12-12-09, 04:48 PM | #16 |
When searched on AC motor speed controls, I got that router unit as a hit.
I figured it would work with Induction motors because of the description: "The variable speed dial allows for full horsepower and torque at all speeds from 0 to full RPM. Use with routers, sanders, grinders, drills & 120v AC or universal motor 20 amps or less." I'm pretty sure my old wood stove motor is an induction motor and the speed control the stove shop sold me looked suspiciously like a regular old incandescent light dimmer.. My circulator pumps are all Taco pumps and they all look a lot like this one.. Except for the Bronze pump that came off the old solar HW unit. It looks like brass.. |
12-12-09, 08:53 PM | #17 |
You can use an inverter (VFD) to control the speed of an induction motor. Small induction motors can be controlled by phase angle controls (basically dimmers with additional circuits to ensure balanced control - Dimmer curve hacking ). Just try it and if the motor isn't getting excessively hot, it's working properly. Or use a speed control for a ceiling fan, which are induction motors. (One ceiling fan control I have taken apart is a very simple cycloconverter that reduces frequency and voltage by cleverly skipping AC cycles.)
