Old 05-14-14, 01:10 PM   #1
Default What tools are needed to work on / hack a heat pump?
What do I need to hack a heat pump? I think this is a common question most people would ask when jumping into the DIY heat pump game. I know I've asked it to myself when I was tinkering with fixing some water coolers, and I still don't fully know the answer. So, I figured I'd pose the question to the experts here on the forum.
So, what do you need to hack a heat pump? What is absolutely necessary? What is nice to have? What do you look for in a micron gauge or vacuum pump? Stuff like that. I think I'll probably compile the info here and write a blog post because I think it'll be very helpful to others.
Old 05-14-14, 02:46 PM   #2
  • small tubing cutter
  • flaring tool
  • swaging tool
  • MAPPS gas (or equiv.) turbo torch.
  • sil-phos 4% sliver brazing rod
  • vacuum pump, preferably dual stage, that can pump down to < 100 microns
  • manifold gauge set
  • micron gauge
  • imagination
  • caution
  • gumption
Not necessarily in that order.
Old 05-16-14, 02:43 PM   #3
Inert gas(dry nitrogen or welding argon)
Tubing bender
Leak finding apparatus
Old 06-04-14, 10:53 AM   #4
Semipro
Andy
Thermometer(s).
Semipro is offline   Reply With Quote
