08-03-14, 03:17 PM | #11 | |
Looks like aluminum barrier paint is very effective. Do you have any ceramic left?? Might be interesting to see if that stuff + aluminum paint improved the aluminum reflectivity. Best, -AC
08-04-14, 10:18 AM | #12 |
Do you have any pictures of your test setup? This is something I'd be interested in writing up for the blog.
08-05-14, 12:47 AM | #13 |
I'll snap a few pictures for you. Weather is forecast for full sun the next few days. I do have most of the powder left. I was thinking about testing a gloss finish and or green base with a clear coat with ceramic added. I really wish I could make this work, maybe a radiant barrier with green tint... I was impressed by how well the silver paint works unfortunately it might look out of place on my siding!
08-07-14, 11:48 PM | #15 |
I took a lot of reading over the last several days. Surface temps varied some, the satin was always a few degrees cooler than the 2 ceramic boards. The aluminum painted board well showed well under but...that seems to have been more because of its reflectivity and its effect on my thermometer. Most ir guns compernsate for .98 emissivity and most aluminums rate under .2 .Making this more obvious was when I measured the unpainted back sides of the same siding samples. The satin averaged 7 degrees cooler than the other 3 samples. The back side of the 3 samples coated with radiant barriers and ceramics were the same regardless of coating. An over simplified account for temperature readings after 4 hrs of full sun would be...Satin finished green surface 134f, back side 114f. Ceramic beaded samples 141f, back 121f. Aluminum radiant barrier paint sample surface 104f (not reading correctly), back side 121F. The ceramic bead additive makes the surface rough and gives it a matte finish. I believe that is the cause of the addition heat gain. Based on these results I'd like to test a gloss finish for any reduction on temps.
08-08-14, 12:07 AM | #16 |
One more thing, about ceramic...I took a piece of green ceramic tile, left it with the siding samples. Same surface temps as the the warmest 3, back side measurement same 141F as the surface 141F. It has no magical heat reflective properties, and no great insulative value. At least with the wood siding there was a 20F difference between front and back.
08-08-14, 03:23 PM | #17 |
08-09-14, 03:24 AM | #18 |
I did an experiment with the ceramic balls you add to paint around 6 years ago.
At the time I was working for a company that had a thermal imaging camera so used that for testing. I constructed a wooden box with a light pendant inside as a heat source and painted 2 sides with white paint and the other 2 with the same white paint and ceramic beads added. The sides with ceramic beads added were showing hotter on the thermal imaging camera so I gave up and binned them. Steve |
08-09-14, 10:40 AM | #19 | |
08-09-14, 11:47 AM | #20 |
The ceramic is acting just how a brick on the house does. It will hold the heat and release it slower so, while it is not so good for cooling the house, it would help in heating the house. They say my double brick (no insulation) house has an R value of 8 at best yet it costs less to heat than most houses with R22 or greater batt insulation. Mass is good.
The Following User Says Thank You to Mikesolar For This Useful Post: | buffalobillpatrick (09-10-14) |
