02-14-15, 04:37 PM | #1 |
Arduino R290 Suction Line Superheat Calc.
Some Arduino code that calculates Suction Line Superheat for R290 (propane)
Saturation Temp / Pressure table: HC-290 (PROPANE) PRESSURE - TEMPERATURE CHART Must use a Pressure Sensor like this: http://www.ebay.com/itm/271763798948...%3AMEBIDX%3AIT Pressure must be between 30 -> 150PSI Pressure Sensor & Temp sensor are placed close together on Suction Line. Code:
/******************************************************** * * ARDUINO R290 Calculate Suction Line Superheat. * * Note: REQUIRED SENSOR * Suction Pressure Sensor: 0-150PSI with output of .5 -> 4.5vdc * * If in DEBUG mode, values are forced to test code function * * In Void Loop: * , read Suction Temp sensor (analog NTC thermistor) * * , read Suction PSI sensor * , convert_raw_sensor_to_PSI * , if input parameter Raw_ADC is not in bounds (between 266 -> 921) * , hang forever1 * * , Calc_R290_Saturated_Temp * , if input parameter Suction_PSI is not in bounds (between 30 -> 150PSI) * , hang forever2 * * , calc Suction Superheat * Repeat * * * Change History: * 02/14/15 Coded, BBP * * * ********************************************************/ #if defined(ARDUINO) && ARDUINO >= 100 #include "Arduino.h" #else #include "WProgram.h" #endif #include <Wire.h> #include <LCD.h> #include <LiquidCrystal_I2C.h> #define DEBUG 1 //#define DEBUG 0 #define I2C_ADDR 0x3F // <<----- Add your address here. Find it from I2C Scanner //D3 #define BACKLIGHT_PIN 3 //define LCD digital pins #define En_pin 2 #define Rw_pin 1 //can't use D0 & D1 Tx, Rx #define Rs_pin 0 #define D4_pin 4 #define D5_pin 5 //can use D2 -> D12 below in code #define D6_pin 6 #define D7_pin 7 LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin); #define SDA A4 //RESERVE I2C for LCD #define SCL A5 // pinMode(A0, OUTPUT); //This works acording // http://arduino.cc/en/Tutorial/AnalogInputPins // digitalWrite(A0, HIGH); // #define Suct_Temp_sensor_pin A0 #define Suct_PSI_sensor_pin A1 float Raw_ADC, Suct_PSI, Suct_T, Saturated_Temp, Suct_Superheat; int Y; void setup(void) //Start Setup { pinMode (Suct_Temp_sensor_pin, INPUT); pinMode (Suct_PSI_sensor_pin, INPUT); // Serial.begin(9600); // start serial communication // delay(10000); //time to enable monitor window // Serial.println(F("........Hello world!.......")); // delay(100); lcd.begin (16,2); // <<----- My LCD is 16x2 lcd.clear(); //Switch on the backlight lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE); lcd.setBacklight(HIGH); lcd.clear(); lcd.home (); // go home lcd.print(F("R290_SUPERHEAT_1")); delay(10000); if(DEBUG) { lcd.clear(); lcd.home (); // go home lcd.print(F("DEBUG = ON")); delay(10000); } else { lcd.clear(); lcd.home (); // go home lcd.print(F("DEBUG = OFF")); delay(10000); } } //end setup void loop () { Suct_T = (Read_10K_NTC (Suct_Temp_sensor_pin)); //read Suction Temp sensor if(DEBUG){ Suct_T = 50;} lcd.clear(); lcd.home (); // go home lcd.print(F("SUCT_T=")); lcd.print(Suct_T); lcd.print(F("*F")); delay(10000); Raw_ADC = analogRead(Suct_PSI_sensor_pin); //read Suction PSI sensor if(DEBUG){ Raw_ADC = 400;} Suct_PSI = convert_raw_sensor_to_PSI( Raw_ADC); lcd.clear(); lcd.home (); // go home lcd.print(F("SUCT_PSI=")); lcd.print(Suct_PSI); delay(10000); if (Suct_PSI == -1) //Suct_PSI is out of bounds { lcd.clear(); lcd.home (); // go home lcd.print(F("RAW_PSI_NG")); lcd.setCursor(0,1); lcd.print(F("HANG_FOREVER_1")); do{Y = Y;} while (Y == Y); //hang forever } else { //else in bounds Saturated_Temp = Calc_R290_Saturated_Temp(Suct_PSI); lcd.clear(); lcd.home (); // go home lcd.print(F("SAT_T=")); lcd.print(Saturated_Temp); lcd.print(F("*F")); delay(10000); if (Saturated_Temp == -1) //Suct_PSI is out of bounds { lcd.clear(); lcd.home (); // go home lcd.print(F("SUCT_PSI_NG")); lcd.setCursor(0,1); lcd.print(F("HANG_FOREVER_2")); do{Y = Y;} while (Y == Y); //hang forever } else { Suct_Superheat = Suct_T - Saturated_Temp; //calc Suction Superheat lcd.clear(); lcd.home (); // go home lcd.print(F("SUPRHEAT=")); lcd.print(Suct_Superheat); lcd.print(F("*F")); delay(10000); } } //end else in bounds } //end forever loop float mapfloat(float x, float in_min, float in_max, float out_min, float out_max) { return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min; } //input parameter Raw_ADC must indicate between 30-150 PSI (266-921) float convert_raw_sensor_to_PSI(float Raw_ADC) { //Pressure sensor output .5v = 0PSI, 1.3v = 30PSI, 4.5v = 150PSI //analogRead results .5v = 102, 1.3v = 266, 4.5v = 921 #define PSI_0 102.0 //ADC of .5v #define PSI_30 266.0 //ADC of 1.3v #define PSI_150 921.0 //ADC of 4.5v #define PSI_max 150.0 float PSI; if ((Raw_ADC >= PSI_30) && (Raw_ADC <= PSI_150)) //Bounds check { // in bounds, continue PSI = mapfloat(Raw_ADC, PSI_30, PSI_150, 30.0, 150.0); return (PSI); } //end if in bounds else {return (-1);} // error return, out of bounds } //end of convert_raw_sensor_to_PSI //input parameter Suction_PSI must be between 30-150 PSI float Calc_R290_Saturated_Temp(float Suction_PSI) { #define Array_size 14 //Array element [0] contains Saturation_Temp *F for 30PSI, //Array element [1] contains Saturation_Temp *F for 40PSI,...................> //Array element [12] contains Saturation_Temp *F for 150PSI, //Array element [13] contains Saturation_Temp *F for 160PSI float R290_Saturation_Temp [Array_size] = {7.93, 18.80, 28.42, 36.91, 44.59, 51.63, 58.13, 64.21, 69.90, 75.27, 80.35, 85.18, 89.78, 94.19}; float Val, Next_val, Span, Saturation_Temp, decimals, work; int I; if ((Suction_PSI >= 30.0) && (Suction_PSI <= 150.0)) //Bounds check { // in bounds, continue //convert Suction_PSI to array index work = ((Suction_PSI - 30.0) / 10.0); I = work; //drop decimals to get array index decimals = work - I; //restore decimals to allow interpolation between array points Val = R290_Saturation_Temp[I]; //get array value Next_val = R290_Saturation_Temp[I+1]; //get Next array value Span = Next_val - Val; //Calc Span Saturation_Temp = Val + (Span * decimals);//interpolate between array points return (Saturation_Temp); } //end if in bounds else {return (-1);} // error return, out of bounds } // end Calc_R290_Saturated_Temp int Read_10K_NTC (int which_sensor) { #define sample_cnt 30 float alpha = 0.9; // factor to tune float average = 0.0; float steinhart; int I; // resistance at 25 degrees C #define THERMISTORNOMINAL 10000 // TEMP. for nominal resistance (almost always 25 C) #define TEMPERATURENOMINAL 25 // The beta coefficient of the thermistor (usually 3000-4000) #define BCOEFFICIENT 3892 // the value of the series resistor #define SERIESRESISTOR 10000 for (I=0; I< sample_cnt; I++) { average = alpha * analogRead(which_sensor) + (1-alpha) * average; delay(10); } // convert the value to resistance average = 1023 / average - 1; average = SERIESRESISTOR / average; steinhart = average / THERMISTORNOMINAL; // (R/Ro) steinhart = log(steinhart); // ln(R/Ro) steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro) steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To) steinhart = 1.0 / steinhart; // Invert steinhart -= 273.15; // convert to C return (round(steinhart * 1.8) + 32); // round to whole number // & convert to F } // end of Read_10K_NTC Last edited by buffalobillpatrick; 02-14-15 at 07:39 PM.. |
02-14-15, 05:21 PM | #2 |
BBP, did you write all this? If so, I'm impressed
Now, could there be one written for subcooling which can control an EEV |
The Following User Says Thank You to Mikesolar For This Useful Post: | buffalobillpatrick (02-14-15) |
02-14-15, 05:34 PM | #3 |
Yep wrote it. Got the idea from BradC post
http://ecorenovator.org/forum/geothe...-gas-gear.html "I've built the R290 PT Chart into the software, and that pressure sensor is a Carel ratiometric. The LCD gives me the saturated suction temperature (SST), and also the real temperature from the little silver probe (A Dallas DS18B20 digital unit) so I can instantly see the real-time evaporator temperature and superheat. The rotary encoder on the panel allows me full manual control over the EEV, so I can twiddle the knob and observe the effects." |
02-18-15, 12:05 PM | #4 | |
The Following User Says Thank You to AC_Hacker For This Useful Post: | buffalobillpatrick (02-18-15) |
02-18-15, 12:25 PM | #5 |
BBP,
Thanks for the thanks, but I am asking you if you did a look-up table? Reason is that I crafted a single formula that will generate the R-290 P-T table, precisely, no need to interpolate. One line of code, no table. -AC
02-14-15, 10:32 PM | #6 |
Using a pressure sensor is the hard way. All you need are two temperature sensors.
The Following User Says Thank You to NiHaoMike For This Useful Post: | buffalobillpatrick (02-15-15) |
02-15-15, 07:39 AM | #7 |
I wish i had the knowledge to write code but I don't.... yet. I am a programming luddite so it is really hard for me.
BBP, could you write one with 1 thermister instead of the pressure sensor and the thermister? If you want to replicate a standard TXV, one would be enough, no? I looked on the Fujitsu circuit diagrams and do not see a pressure sensor anywhere, just numerous thermisters. As they are just plug in to the board, I don't know if one or two (or three) are used to control the EEV |
The Following User Says Thank You to Mikesolar For This Useful Post: | buffalobillpatrick (02-15-15) |
02-16-15, 02:36 PM | #8 | |
Just a simple wave of the wand...
After a certain amount of testing has transpired, the log data is analyzed. What happens next depends on what type of control system the unit employs. With a primarily mechanical control system, not a whole lot can be changed beyond tweaking offset adjustments or system component configuration. Due to the static, predictable nature of cap tubes and txv's, they are a "set-it-and-forget-it" type of device. With the new, variable speed compressor and electronic expansion valve driven systems, this is no longer the case. The control board on these devices has been put through countless hours, months, and years of torture testing, both simulated and real, before a single production unit is released. The mechanical and refrigeration engineers have had their way with the entire control system many times over. Just because there are only a few thermistors included in the final production model (to save money) does not mean that there aren't secret routines lurking in the abyss that is the control program. When a dog pees on the outdoor unit while it is running, some engineer somewhere has thought about it already and included a countermeasure. When you mismatch the indoor and outdoor units, the brain can tell. Many real-time variables are calculated in the background, based on the model developed in the torture lab. To the average user, the unit just runs like it should until it won't. A txv uses pressure to regulate superheat. The suction line bulb is charged with very close to the same gas as the refrigeration circuit. The pressure in the bulb follows the saturated suction line pressure as the temperature changes. This pressure acts against one side of the diaphragm that opens or closes the needle valve. The other side of the diaphragm sees either valve discharge pressure (internally equalized) or suction pressure (externally equalized). The adjustment on the valve adds a little closing pressure to the valve to ensure some superheat exists. A subcooling valve works in much the same manner, only the bulb follows saturated condenser pressure and the diaphragm is externally equalized to condenser pressure. Most of the new EEV units use indoor tube temp, outdoor tube temp, and compressor discharge tube temp thermistors at the least to figure out a partial picture of what's going on with the unit. A great many of them also have indoor and outdoor ambient thermometers also. The inverter units have a startup ritual they go through when the unit is powered up or a mode change occurs. This initialization routine tells the unit how to act. Who knows how much magic is packed in there? |
The Following User Says Thank You to jeff5may For This Useful Post: | buffalobillpatrick (02-17-15) |
02-17-15, 06:30 PM | #9 | |
That said, there are more ways to build a HP than the traditional TXV or cap tube. I'm not going to measure SH with the one I want to build next, it is run with a subcooling valve which is only concerned with single phase liquid temp, not trying to keep a constant SH. Theoretically, all that should be needed is one thermister on a liquid line and the proper PID to control it. |
02-15-15, 11:31 AM | #10 |
NiHaoMike, where would those 2 temp. sensors be placed on a coax evaporator?
See: post #108 http://ecorenovator.org/forum/geothe...html#post39145 |
