Old 11-11-11, 08:31 PM   #11
I think you posted this entry to the wrong thread...
I think you meant to post this entry to this thread.
I guess that I should have explained the point of my post..
Using the X10 output of the CAI board, already gives me some control of Sanyo#1.
Since I can turn it off and on. (I may set up Sanyo#2 the same way).
I added the part about the current sensors, since that will allow the CAI to watch power use,
and automatically shut down the system, if it malfunctions and draws too much power.
(A big problem with my systems).
Of course, the eight TTL outputs (SSR compatible) would be best way to
control the functions of a system. Much more reliable.
From now on, I'll try to avoid posting anything to this thread..
