Advanced Search |
10-28-14, 05:32 PM | #41 | |
I said store "short term". Gas cans are a lot cheaper and more portable than extra propane bottles. Transferring propane from one bottle to another requires a special pump or cooling. (If you simply connect 2 propane bottles together, you can never "fill" the empty one completely.) If propane is such a "wondrous" fuel for internal combustion engines, why is it not used more often, especially on all vehicles (motorcycles, ATV, boats, snowmobiles, etc) ? Maybe it the addition size and weight of the tank ! I am pretty certain that when propane is used as an "on the road" vehicle fuel it is subject to the same federal (18¢/gallon) and MI state (19¢/gallon) plus a 6% sales tax. Last time I filled my 20 lb propane bottle/cylinder I think I paid about $15, with no "road taxes", or about $3.15/gallon. Add in the 37¢/gallon road tax and we are at $3.52/gallon (rough number, please correct me if I made any mistakes in my math). After "super storm Sandy", I'm certain that propane was no easier to obtain than gasoline. I would not want to try wrestling a 30-40 lb bottle in the back of MY car ! Frito-Lay has converted all of their delivery trucks to propane, but they are buying their fuel at wholesale prices. Some city buses and some school buses also. So in the right application, it does make sense ! Last edited by theoldwizard1; 10-28-14 at 05:36 PM.. |
10-28-14, 05:56 PM | #42 |
I am addressing your concerns best I can, sorry for the tone it leaves , I have no reason to be gentle in my responses. I am more concerned with being truthful, to myself.
Quote: After "super storm Sandy", I'm certain that propane was no easier to obtain than gasoline. I would not want to try wrestling a 30-40 lb bottle in the back of MY car ! ~~~~~~~~~~~~~~~~~~~~~~~~ You would rather haul stinking gasoline containers over propane in a bbq tank , you do like gasoline don't you. You do not need to transport Propane to your house in 40 lb bottles if your not capable of it , 20 lb tanks last a reasonable amount of time before needing to be switched. |
10-28-14, 06:23 PM | #43 |
Depends on how fast it is consumed. A 5KW generator can consume a lot of propane. My guess is 2 - 4 20lb tanks per day, depending on the load.
10-28-14, 07:53 PM | #44 |
Wizard either way you would be working your *** off ,hauling gasoline or packing Propane.
I think Propane makes sense more for individuals than for all , its good for the needs of some of the People out there. |
10-28-14, 08:02 PM | #45 |
My bbq is Propane My fireplace is Propane soon my car will be Propane enriched / Dual fuel.
10-28-14, 11:49 PM | #46 |
I have owned 2 Propane Vehicles in the past , one a 1 ton flat deck and the other a 1/2 ton chevy pick up. They both drove so quiet and cleanly they were a treat to own. The 1 ton got amazing mpg with its 318 wide block and 4 speed transmission. The 318 wide block was basically a commercial dodge 318 motor with a longer stroke.
04-27-15, 10:01 PM | #47 |
Vlad,
Hopefully you are still monitoring this thread. I finally bit the bullet and bought most of the parts to convert my craftsman 24 hp v-twin Platinum Briggs and Stratton powered garden tractor (engine model 44S877). So far I have: Beam T-60B (with vacuum lock off) 12 V solenoid lock-off valve, high pressure Left handed POL cylinder fitting, safety high pressure regulator, pre-assembled rubber hose with 3/8" flair swivel ends & brass fitting. It seems i will need a source of vacuum for the zero governor, and a way to distribute the propane in the carburetor. I attached a pic of my engine. My questions so far: Is the location of the propane feed important in the carburetor? It seems to be best below the choke plates, but I have see people feed above the plate, and even in the air cleaner box. Since I don't want to drill the carb (it's new), my options are either an aluminum spacer or a motor snorkel (looks easy, but a bit pricey): http://www.motorsnorkel.com/media/ca...13_3_1_3_7.jpg The other thing I was wondering is if the propane needs a lot of help to be distributed evenly in the air stream. Most aluminum spacers seem to have a venturi machined in, and a small machined ring on the inside to distribute the propane. I know you have just drilled a couple of your carbs and added another emulsifier tube. Is that enough for a thorough mix to take place in the air stream? Many questions. Now to find silfos brazing rod and some decent a/c copper tubing. Hopefully that small capped off hose on the side of the engine is a source of vacuum, needed for the California version. If so, I promise to say at least one good thing about California emissions law Last edited by Daox; 04-28-15 at 07:40 AM.. |
05-05-15, 06:14 PM | #48 |
The engine, minus cooling shroud.
05-05-15, 06:23 PM | #49 |
Closer view of the air box. The breather port (square opening) looks like it could be an ideal vaccum lock out release hose, but will it be enough vacuum so high near the air filter?
Or would I be better off teeing into the larger crankcase hose? |
05-05-15, 06:55 PM | #50 |
More pics of the air box. This looks like my best bet to place the propace feeds/venturis.
