Old 06-03-15, 12:17 PM   #141
I looked up this 18W 12 V air pump with the link you sent. I see it puts out 38 L of air/minute (~ 10 gallons). Do you know what pressure it can achieve? I want to put the far end of the air hose down about 30 feet (about one atmosphere; 15 psi).
Because it is a piston driven one, I think this is positive displacement and I bet it can put out a lot of pressure. This would be PERFECT for my pond aeration needs.
If you get a chance, can you see what it will put out in terms of psi. I don't see any psi vs volume graph in the online specs.
Thanks,
You could rig up an air lift column to the pump cited to save energy but still circulate deep water. I used a corrugated lateral line section that hung from about a foot underwater to about a foot from the bottom. The cold water gets aerated, then falls right back down low. We used rubber diffusers to keep the back pressure low. Works like magic.
Old 06-03-15, 12:25 PM   #142
Jeff, - that is exactly what I was planning to do. I may put the air stone as deep as possible to get additional lift. This air column concept looks superb as it can bring up deep water, without having the air stone down that deep.
Thanks!
Old 06-03-15, 12:35 PM   #143
Ok we made it back home with 30 tilapia about 4-5 inches long. This is a good size to start with. We had to transfer them in 5 gallon buckets down a bunch of stairs one jumped out of my sons bucket.
This fish fell about 15 feet to cement and was flopping around. I put it back in the water it seem fine.
They all made it here safe into my fish tank. My new air pump ran great we had it runing for about 2 hours.
Here are the fish in their new home.
The water is this color from the iron added to the system.
ID:	5411   Click image for larger version
Old 06-03-15, 02:21 PM   #144
Here they are in the tank it is only 18 seconds.
Old 06-04-15, 09:23 AM   #145
They all survived the night. The fish that took the big jump to the cement. Was looking very bad but he is still hanging on. I will be surprised if he makes it.
I did not feed them yesterday but I just tried to feed them today but they are not ready to eat just yet maybe later.
Water is @ 69 deg
All the water test are very good.
PH it is about 7.2
Ammonia is about .0
Nitrite 0 ppm
Nitrate is showing up at about 30
This is my first time raising fish so it may take a few days for me and the fish figure it all out.
We tried again and we got a few of them to eat a little. The others look like they want to but are just not brave enough to come to the top just yet. They get hungry enough they well come up and get some food.
Old 06-05-15, 08:48 AM   #146
Ok bring on the plants.
The tomatoes are not doing so good.
Broccoli are doing better they have grown at least an inch since we got the fish.
Cucumber has gotten greener and grown some.
The water is really too cold for the fish right now 65 deg so they are not very hungry.
It has not been very warm or sunny they last couple days.
ID:	5417   Click image for larger version
ID:	5418   Click image for larger version
ID:	5419   Click image for larger version
ID:	5420   Click image for larger version
Old 06-05-15, 09:27 AM   #147
The floating fish food I have is a very nice size for these small fish.
I just need warmer water to so they will want to eat.
It was inexpensive I think it was $14 for 40 pounds.
The guy I got the fish from was very cool he just gave me the fish to get me started.
Old 06-05-15, 09:30 AM   #148
Wow, very nice!
How warm do the fish like to be?
Old 06-05-15, 09:34 AM   #149
82-86 is where Tilapia want to be. That is why I will probably switch fish at the end of the summer.
"Bluegill try to spend most of their time in water from 60 to 80 °F"
It will be a lot cheaper to keep the water at the right temp for Bluegill. The catch is the plants like warm water on their roots.
"Tilapia culture is limited by their temperature-sensitivity. For optimal growth, the ideal water temperature range is 82 to 86 °F (27.7 °C to 30 °C), and growth is reduced greatly below 68 °F (20 °C). Death occurs below 50 °F (10 °C). Therefore, only the southernmost states are suitable for tilapia production."
Daox (06-05-15)
Old 06-06-15, 08:26 PM   #150
Day twenty-something update:
I have basically done nothing with this since I added acid to balance the pH. It has been cloudy and rained a few times, just got sunny this weekend.
Maybe I'll add a couple goldfish this weekend. Or mosquito-eating minnows.
