Old 12-31-12, 07:59 AM   #291
kostas
Hi all,
I finally finished the DIY HRV and plugged it to the wall of my living room!
It's been working for about an hour now at minimum velocity, outside temperature is 10,0 degrees Celcius, inside T is 21,1 and incoming fresh breeze (top) at 19,0!! The thing is rocking real good!!
Have a happy new year people, see you on 2013
kostas is offline   Reply With Quote
The Following 2 Users Say Thank You to kostas For This Useful Post:
Daox (12-31-12), Piwoslaw (12-31-12)
Old 12-31-12, 08:10 AM   #292
Very nice Kostas! Congrats on getting it up and running, and at a great efficiency it seems.
kostas (12-31-12)
Old 12-31-12, 08:59 AM   #293
Originally Posted by kostas View Post
...The thing is rocking real good!!...
Congratulations kostas, on a job well done.
I hope your success starts a tsunami of DIY HRVs!
It might be helpful if, all on one page, you made a list of any details you think are important for someone interested in building their own HRV similar to yours... things like Height, Width Depth of box, Height, Width Depth of each core, wattage of fans, core material, and any other details you think might be useful, too.
Very good job!
Best,
Old 12-31-12, 10:49 AM   #294
Piwoslaw
Piwoslaw's Avatar
Kostas, isn't that box missing a wall?
Old 12-31-12, 11:51 AM   #295
WD-40
Thats awesome work and results.
I'm going to try my hand at a very similar but smaller unit for my clothes dryer.
And if that works out ok then a larger unit for fresh air.
This blows away retail units for results not to mention the cost.
Another success for the DIY market.
WD-40 is offline   Reply With Quote
Old 12-31-12, 12:52 PM   #296
kostas
Thanks everyone for your comments, really appreciate them
AC: yes, I have in mind a full detailed how-to-do instructions. As soon as I have the list down I'll be glad to have your helpful comments for it, too
Piwoslaw: yeh, I totally forgot the door!! That means that it could be over 101% efficient
Old 01-01-13, 05:36 PM   #297
mini23
Fantastic work kostas, a simple design that operates perfectly, beating most mass produced units, at 101%, even better.
Will definatly be having a go myself.
Will be good to see your air flow.
mini23 is offline   Reply With Quote
Old 01-02-13, 03:23 AM   #298
kostas
Thank you, minie23, I'm glad to inspire others to do the same
As for the air flow, I was planning to use o e of these: Techno Line Wind Meter EA 3010 Wind Guage buy now - Conrad Electronic SE Wind Gauges Electronics Online Store
Old 01-08-13, 04:15 PM   #299
Fornax
My build took a tad longer. Today I managed to do a Q&D connecting, but the entire contraption is not finished yet.
Air is flowing but I did not do any thermal nor acoustic insulation. My son asked about that while running at the lowest setting, and stated the noise needed no care at all. (If you knew what to listen for you could tell it apart from the sound computers make.) At higher settings both airflow and sound are more noticable.
More disturbing to me: temperature readings are not looking as good as what Kostas gets. I need to investigate this.
Fornax is offline   Reply With Quote
Old 01-08-13, 05:00 PM   #300
kostas
Good job, Fornax. Give us some data, temperatures, air flow, hx dimensions. I guess you can improve it furthermore
erv, heat recovery, hrv
