Old 02-12-14, 01:02 PM   #1
Default Top 10 Conservation Tips for Renters
I was poking around and saw this today:
Top 10 Tips for Renters : ENERGY STAR
Its definitely not the best list, but its somewhere to start if you're renting.
Perhaps we can find some better things to add to the list?
Old 02-12-14, 01:21 PM   #2
jeff88
Lots of questions
Um, why would you install a 2.5GPM shower head when you can install a 1.25 or 1.5GPM shower head?
A renter can also purchase a portable induction cooktop rather than using the complex supplied appliance (gas or electric).
Use a blanket (or electric blanket) instead of the heater.
Buy a Kill-a-Watt!!!
jeff88 is offline   Reply With Quote
Old 02-12-14, 01:35 PM   #3
ecomodded
from the list:
Interesting that 90% of the cloths washers energy usage is from the hot water consumed.
I wash and rinse in warm water as Cold water leaves jeans dirty and removes less soap residue when rinsing , is what I find. Hot water is not needed for bright cloths.
Servicetech (02-15-14)
Old 02-12-14, 02:31 PM   #4
Hack a window air conditioner and turn it into a heat pump. Beats the holy crap out of electric resistance heat.
Old 02-13-14, 02:06 AM   #5
oil pan 4
Land owner
Pay rent so you dont get evicted and have to leave everything behind.
Old 02-13-14, 07:01 AM   #6
RobbMeeX
Eco OWNER!!
Buy a house... Knocked our rent right in half!
In it for the money (savings)
RobbMeeX is offline   Reply With Quote
Old 02-13-14, 09:14 AM   #7
NiHaoMike
NiHaoMike's Avatar
Or if modding is out of reach for you, just set the unit in the room with the hot side facing you. No modding needed whatsoever. It would then take the heat that's already in the room and "concentrate" it where you want it. Might work better if you could bypass the thermostat so it will keep working down to lower temperatures, but that's easily done in minutes with common tools.
Bitcoin or something similar might be a good choice if a heat pump is not an option. You can even make use of "unprofitable" used hardware - it just has to make enough to make it worthwhile.
And there's also the "low tech" reflector incandescent or halogen bulb...
Old 02-15-14, 12:21 PM   #8
Servicetech
Servicetech's Avatar
A standard window AC would freeze up at outdoor temps below about 60. Not useable as a heat pump when simply put in the window backwards.
Old 02-15-14, 12:23 PM   #9
Servicetech
Switching from electric to gas dryer (if there is a connection) will save more money than using cold water for the washing machine.
Old 02-15-14, 12:26 PM   #10
Servicetech
Programmable thermostats only save money when set correctly. Unfortunately most are NOT set correctly.
