11-19-12, 05:15 AM | #1 |
Air Source Heat Pump Water Heater DIY Install
Xringer has finished up yet another project. This time around he has installed an air source heat pump water heater called an A7 AirTap. Its a retrofit kit that allows you to add a heat pump that is installed on a conventional electric hot water tank (or any water tank really). The AirTap will be [...]Post from: EcoRenovator.org
Air Source Heat Pump Water Heater DIY Install More... |
