Old 02-16-12, 08:14 PM   #51
rhino 660
priming the loops
i got my heatpump FHP 2 ton with ECM blower
and some solar goodies outback vfx3648 3600 watts 48V grid tied battery backup inverter, outback fm80 80A charge controller, and midnight solar's combiner box. got this as a bonus from my boss.
im going to run 4kw dc to it
i drew up some plans for doing a ground mount
rhino 660 is offline   Reply With Quote
Old 02-16-12, 09:26 PM   #52
rhino 660
while priming my loops the temp gauge remained at 72*F
Old 02-19-12, 11:05 PM   #53
rhino 660
i built ducting out of 3/4'' foam board, i just have to finish a 15' run in the attic
Old 02-19-12, 11:06 PM   #54
rhino 660
The Following User Says Thank You to rhino 660 For This Useful Post:
RobbMeeX (06-07-13)
Old 02-19-12, 11:18 PM   #55
rhino 660
i ordered some more parts for my priming setup. what im going to do is hook everything up minus the loop pump and use a ball valve to choke down the priming pump output to 8 gallons a minuet and check the pressure at the pump output from there i can perfectly size the circulator pump needed
Old 02-19-12, 11:26 PM   #56
Man, that's one busy weekend! Very Nice work on the duct-work!!
Looks like you are going be making the power to run that system too..
Old 02-20-12, 12:00 AM   #57
rhino 660
yes lots of work im also doing solar hot water after i finish these to projects after all that stuff i should have no power bill
Old 03-05-12, 09:22 AM   #58
rhino 660
i finished all the ducting this is the attic portion
i allmost have all the fittings i need to check the head pressure
RobbMeeX (06-07-13)
Old 03-05-12, 04:44 PM   #59
creeky
creeky's Avatar
nice set up. look forward to seeing more.
Old 03-05-12, 08:27 PM   #60
rhino 660
thank you i got antsy and decided to test run my unit with the priming pump, i got great results. i wired the loop pump into the compressor relay.
thermostat i stole off my wall
this is the pressure with the pump at full blast
heating mode temp return from loopfeild
heating mode temp to loopfeild
cooling temp return from loopfeild
cooling temp to loopfeild
i just need to devise a scheme to measure the gpm and then check the pressure so i can get a proper pump
RobbMeeX (06-07-13)
