Old 01-08-13, 07:55 AM   #11
The problem is, if you give 40k peple $5k they'll probably put it towards a new SUV or something stupid. Even if it does cost more, at least its going towards a good cause. Those panels will be around for a long time and will pay for themselves eventually.
Ryland (01-08-13)
Old 01-08-13, 08:48 AM   #12
Ryland
I'll bet the installed cost of those PV-on-a-post is about $1,000 each. Or, about $5 a watt.
If you buy USA made panels with built in micro inverters they come out to $2 per watt and should be really quick to install, bolt it on, connect the wires and you are done.
Helios SolSimple AC Module
Of course I'm sure they would give you a discount if you were buying 40mega watts worth.
