Old 03-18-14, 12:52 PM   #1
Default Heatworks model 1 (electric tankless water heater)
While nothing completely revolutionary, this looks like a nice upgrade to existing tech that not only makes things more reliable, but also hopefully cheaper.
I like the carbon heating element vs the spring style. The idea of wifi controlled temperature is very nice. I also like that it has no flow switch... but I'm wondering how they detect water flow with out one?
Thoughts?
https://www.kickstarter.com/projects...r?ref=category
http://myheatworks.com/
Old 03-18-14, 07:12 PM   #2
Reading through the details, it says that normal tankless heaters take 30 seconds to get warm, with a graph showing a ramping temperature. Is that your experience with the output of your Stiebel Eltron DHC-E 10? This has been something I've been thinking about a bit lately and has been on the back burner to ask about but seeing this in their 'campaign article' makes me want to know.
Old 03-19-14, 07:46 AM   #3
Without taking measurements, I'd say it probably does take a little while for it to heat up. It does hold a small amount of water in it, and I'm sure it can't heat that up instantly. I think 30 seconds seems a bit much though. And, the Model1 is very close to the same power output as my DHC-E 10 which is 9.6 kW, the Model1 is 11.5 kW.
I would imagine that the volume of water held in the unit has a large effect on how fast it warms up. I would think the Model1 would heat it faster because it is using the water as the resistor, not a heating element. However, you are still putting 9.6kW or 11.5kW into the water heater.
Here are the guts of my DHC-E 10.
Old 03-20-14, 06:59 PM   #4
Servicetech
Servicetech's Avatar
The problem with using water as the resistor is impedance will vary depending on the hardness of the water.
Old 03-20-14, 07:56 PM   #5
I am assuming they've covered their bases. They probably have a current sensor that monitors how much power is going in and it adjust PWM duty cycle accordingly.
