Old 11-24-08, 02:02 AM   #11
groar
X-Frenchy: very
groar's Avatar
Default Hourly production of 2008/11/23
I will not do it everyday, but I thought it could be interesting once.
Yesterday's weather was variable, but mainly cloudy. An average November day should generate 3.6kWh. Yesterday only 2.37kWh were generated.
The sunrise was at around 8h and the sunset at around 17h30. The inverter switched on at around 8h15 and began to produce at around 8h30, but the reselling counter didn't shown any instantaneous power before 8h45. During all the morning, the sun didn't appeared. Don't forget also that our PV system is toward the West and the sun can't see it before 10AM, so before that it's only the ambient luminosity that generates power.
Code:
 time WInv WRes DaWh OutA InV#1/2 InA#1/2 G/R
08h00    0    0    0                      0/1
09h00   25   20    9 0.62 197/183 0.2/0.1 1/0
10h00  105   80   70 0.89 210/193 0.3/0.2 1/0
11h00  227  250  216 1.41 213/187 0.7/0.7 1/0
12h00  379  410  498 2.14 233/220 1.1/1.0 1/0
13h00  416  440  944 2.23 233/216 1.0/1.0 2/0
14h00 1580 1680 1523 7.05 235/218 4.1/4.1 5/0
15h15   82   80 2197 0.87 205/188 0.3/0.3 1/0
16h00  175  150 2322 1.23 211/195 0.5/0.4 1/0
17h00    0    0 2370                      0/1
Where :
  • time : clock
  • WInv : Instantaneous W generated by inverter
  • WRes : Instantaneous W received by reselling counter
  • DaWh : Cumulative Daily Wh generated by inverter
  • OutA : Instantaneous A generated by inverter
  • InV#1/2 : Instantaneous V received by inverter in strings 1/2
  • InA#1/2 : Instantaneous A received by inverter in strings 1/2
  • G/R : Number of Green/Red lit LEDs
The instantaneous production shown on the reselling counter is updated less often than the one shown by the inverter, so the first is smoother than the second.
When the Red LED is lit then no production is generated as the power received from the panel isn't enough to generate some power. The Green LEDs correspond to power generated by inverter. Each LED is at most 400W, ie 1 LED means 0-399W, 2 LEDs 400-799W, 3 LEDs 800-1199W... But to switch a LED on or off, the inverter wait to have several consecutive measures in the corresponding range, so at 2PM there was 5 LED for only 1580W.
The new maximum values are :
Code:
Out : 1686W 7.801A 238V
In1 : 1029W 4.441A 279V
In2 :  949W 4.634A 260V
Bad, the In1/2 max values can be seen only when the inverter is switched on by panel power.
Denis.
  • kg saved 06/08-08/09: 1816.9+382.9 (ecodriving / 1420mi not driven) = 2199.8
    (2.66 kg/l diesel)
  • kg saved by 3kWc photo-voltaic solar panels : 187 kg/yr
    (59.1 g/kWh)
  • Long life (>100,000 years) : 2.85 g/yr (0.9 mg/kWh)
  • Short life (<300 years) : 31.7 g/yr (10.0 mg/kWh)
groar is offline   Reply With Quote
Old 11-24-08, 03:23 AM   #12
toyobug
avid DIY'r
toyobug's Avatar
Denis, those figures are pretty impressive! I'm curious to see what a summer day would produce...
Keep them coming. Good Job!
toyobug is offline   Reply With Quote
Old 11-30-08, 11:28 PM   #13
groar
X-Frenchy: very
groar's Avatar
Default bump...
Updated posts #1 and #8 with the monthly production picture.
Post #8 has been daily updated with daily production from 11/21 to 11/30.
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Last edited by groar; 12-02-08 at 11:13 AM.. Reason: Added links to messages #1 & #8
Old 12-01-08, 07:53 AM   #14
Looks like your averaging around 2 kWh per day? Not too shabby. Do you think this is below or above average? I have no idea what the weather is like in your area this time of year.
Old 12-02-08, 11:25 AM   #15
groar
X-Frenchy: very
groar's Avatar
1.9kWh is only 53% of the forecasted average of 3.6kWh/day in November. It's even lower than the 2.4kWh forecasted average for December.
As you can see in message #8, the daily production for November varies between 532 and 4146 Wh/day. Over 3000, the weather was mainly sunny. Under 1000, the weather was only cloudy.
But the day is short by now (9h11 for today) and any cloud is lowering the production a lot. In February it should be better
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Old 12-07-08, 05:44 AM   #16
blueflame
blueflame's Avatar
This is cool and really makes sense. I wonder if we can get a cheap loan in NZ for solar panels.
Imagine no huge distribution network of pylons, cable and switch stations but small scale producers everywhere.
People out of work could connect a generator to a bicycle, get paid and lose weight!
Imagine in the future every house putting wind generators on their roofs, people oversizing the installation to make more money...
Wish I had free electricity!
blueflame is offline   Reply With Quote
Old 02-04-09, 06:59 AM   #17
jwxr7
jwxr7's Avatar
Hey Denis,
Have you ever seen any power collection during a full moon at night?
jwxr7 is offline   Reply With Quote
Old 02-04-09, 03:10 PM   #18
groar
X-Frenchy: very
groar's Avatar
Never looked at that as since mid-November when my system was connected to the grid the weather has been very cloudy : other people in my region has produced 30% less than one year ago.
As the inverter stops the production before the night, I bet I will never see any production during the night. If ambient light can be enough to generate a voltage, I don't think it will be enough to generate enough power to switch on the inverter. One day I have seen the contrary : the inverter switched off because it wasn't receiving enough power, it was 10 minutes before sunset and the weather was variable.
While I'm noting the production every evening, I'll immediately see night production as my total will not match inverter's.
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Old 02-04-09, 03:35 PM   #19
groar
X-Frenchy: very
groar's Avatar
During these last days I beat several times my best daily production :
  • 2009/01/30 : 4604 Wh
  • 2009/02/03 : 5035 Wh
  • 2009/02/04 : 5972 Wh
I just realized that as the shortest day is the 21st of December, we have now longer days than in mid-November when the panels were connected to the grid.
I want to see my summer production
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Old 02-05-09, 07:33 AM   #20
knowbodies
Home Improvement Goon
Originally Posted by groar View Post
The reselling price is currently at 0.57187€/kWh, so the income for the first year should be around 1813€ (2284$ at 1,2595$/€).
Whoa! Is that number correct or is that a typo? At current exchange rates, that is 9 times what I pay per KWh (I pay $0.10 per KWh).
knowbodies is offline   Reply With Quote
electric, solar
