Old 12-16-12, 11:00 AM   #261
kostas
Thumbs up
I'm sure that energy is even more dear where you live.
Oh yes, you can say that!
kostas is offline   Reply With Quote
Old 12-16-12, 12:53 PM   #262
TimSmall
Geek about the house
Originally Posted by kostas View Post
Talking about motors, what do you think about this one?
It is a dual centrifugal with these specs:
130 W
2300 rmp
Fan diameter 80 mm (aluminum)
Fan length 83 mm
450 m3/h
static pression 237 PA
For comparison, those mixed flow second hand DV6224 fans which I mentioned (available at 25 euro or so each - I saw a set of four fans on US eBay for $30 I think), do the following at max speed:
89 watts
650 Pa (static)
700 m³/h (open flow)
http://img.ebmpapst.com/products/dat...224TDA-ENG.pdf
but they're speed controllable with an EC motor, so will go down to 10% speed giving 100 m³/h (open flow) and if similar fans which I've used in the past are anything to go by, they probably use less than 5 watts at that speed.
Have a look at the fan curve on the last page of the PDF.
TimSmall is offline   Reply With Quote
Old 12-17-12, 12:29 AM   #263
Piwoslaw
Piwoslaw's Avatar
Two fans are good not only for flexibility, but can also (potentially) reduce energy usage. During the nice warm spring and autumn there will be a few weeks or months when you won't really need the heat exchanger since the outdoor air will be in a good temperature range. Then you can open your windows and turn off the intake fan, using the other one as a house fan to remove stale air from the bathhroom and kitchen.
Old 12-17-12, 04:38 AM   #264
kostas
They are surely interesting, and moreover they could be easily controlled by the Arduino...
I can't see the noise figure, though.
Could you please pm me the ebay link?
Yes. In addition you can always use one of them as mentioned on post #245
Old 12-17-12, 06:36 AM   #265
TimSmall
I found another data sheet, which gives min and max values:
Full Speed:
69 dB(A)
89 watts
700 m³/hr (open flow)
5500 rpm
Min Speed:
29 dB(A)
2 watts
100 m³/hr (open flow)
800 rpm
So the 2 watts figure looks pretty good.
Careful, because I can't say for sure that the Sun variant will be able to go down to the minimum stated (they may have asked EBM Papst to change the firmware for them).
Try these searches (title and description):
DV6224/2tdp
371-0094
x4600 fan
papst 2tdp
I'm a new user so I can't send PMs! You should be able to track them down with the search strings above - PM me your email address if you don't.
Last edited by TimSmall; 12-17-12 at 06:45 AM.. Reason: re pms, clarify re min speed.
Old 12-17-12, 04:54 PM   #266
kostas
Ops! Same for me, too!
Ok, I'll try to search better in the Bay
Old 12-18-12, 02:33 AM   #267
kostas
I found this one in a fairly good price:
PAPST RG160-28/18N/13TDTV
(http://www.ebmpapst.us/allpdfs/RG160DC.PDF)
The curve is not very clear but it goes at least at 225 qm/h, maybe could do the job..
Old 12-19-12, 02:10 PM   #268
Default Thru-Wall HRV...
Here is another look at the problem...
This is a thru-wall HRV. It mounts on the wall and vents to the room, so no ducting is involved.
I thought it is very interesting how the assembly is layed out:
CLICK HERE for higher detailed illustration.
It's interesting how the air flow is incorporated into the design, also the use of an unusual fine wire heat exchanger.
Best,
ID:	2758   Click image for larger version
Old 12-20-12, 03:43 PM   #269
kostas
Interesting variant, Ac
In the meantime I finished the exchangers assembling.
I made one with coroplast sheets and another with aluminum, as I had already the material for both of them. Dimensions are 301x301x400mm each.
Here are some photos of the construction process:
Old 12-20-12, 11:26 PM   #270
Piwoslaw
Piwoslaw's Avatar
I can't wait to see a side-by-side test of them! I'm very interested in the difference in efficiency of the two materials.
erv, heat recovery, hrv
