#1 |
![]() Pi 3 is out built in Wi-Fi, and Bluetooth Low Energy (BLE) on board...
It looks good to me I just ordered one. Same price $35 http://www.newark.com/buy-raspberry-...JAMaArQo8P8HAQ Adding Wi-Fi is a big deal.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 03-02-16 at 04:32 PM.. |
#2 |
![]() Here are some performance test for the new Pi 3
Raspberry Pi 3: How much better is it than the Raspberry Pi 2? - TechRepublic
#3 |
![]() What do plan on doing with it?
#4 |
![]() The plan is to use it on my Aquaponics System. http://ecorenovator.org/forum/lawn-g...-build-61.html My new heat exchanger needs to only run if the fish water is below an 82 F and the peak of the roof (where the heat exchanger is) above 90 F. this does not need to be ready until next winter.
#5 |
![]() I got one to use as part of an altcoin mining setup and it definitely heats up under load! You'll definitely want a heatsink on the CPU.
https://www.loverpi.com/blogs/news/9...portant-notice
#6 |
Guest
Posts: n/a
![]() I've been looking for this new model ....thanks for sharing
