11-20-10, 12:36 AM | #371 | |
Gather up the links, send them to me in an email via the ecorenovator thingie and I'll edit them in. it would be a good idea to include the permalink address of the post where the link was located along with each link... Regards, -AC_Hacker Last edited by AC_Hacker; 11-20-10 at 01:19 AM.. |
11-20-10, 10:55 PM | #372 | |
Renovator-in-planning
Moving site, harvesting threads
I have some tools that may be able to harvest the whole thread from the forum. Of course, accessing the forum thread database directly is the clean way, but if that's not available, I should be able to download all 37 pages. Maybe we can then vote for which ones should be combined to make a wiki or a FAQ. Seth |
11-21-10, 01:40 AM | #373 | |
Sounds good. I like the democratic approach Someone else started out doing a wiki, but the enthusiasm died after a few weeks. The blog approach has its advantages, in that it invites other people to document and present their projects. The FAQ has advantages in that it distills the most essential information. The wiki provides an accessible way for people to share information. I think if I had to choose one, I like the wiki rather than a FAQ. The wiki would suggest another site, also ok. BTW, I just secured the domain name "DIY-GSHP.INFO" for five years... no server yet. Regards, AC_Hacker |
11-21-10, 06:21 PM | #374 |
What I do for a server is I have a Linode.com virtual Ubuntu Linux.
I configured apache to host domains at /my/path/to/domains/domain.com What this means is on the server side, creating a domain is "mkdir ..." I point all the domains I host to one IP address. (and all the mailbox records go to google :-) This approach works for me, because I don't enjoy cpanel; I am either in an editor or a wiki, not much in between. I love pmwiki. Here's a domain that I seeded for a friend - he has done everything that did not require root access, and he is not a programmer. (just a mere Rocket Scientist :-) I like what he did with the Combustion page... http://pachai.net/rgbutler/index.php?n=Main.Combustion |
11-21-10, 07:25 PM | #375 |
pachai,
Sounds good, send me an email via ecorenovator email and we can hammer out the details. -AC_Hacker |
11-25-10, 10:14 AM | #376 |
Late Breaking News to Give Thanks for
B"H
I had a day off and needed to get my 5 y.o. out of the kitchen.... So I did an experiment = I'll try to upload pics. I drilled down 2' without breaking a sweat. I should be able to go down 20' easily. Unless I hit bedrock. But Bedrock might be OK because there is a high water table. But then I'll know if I need a pro to do it. This tool ought to be usable for horizontal boring also. THAT might be an option when my builder digs out a hole 10' deep x 20' wide x 30' long. This is 1.25" pipe. There is an adaptor for 3/4, and a plug. Some Plugs are available with hex head. The Auto Parts store had a 1.125" socket for 1/2" impact wrench. Last edited by pachai; 11-25-10 at 10:17 AM.. |
11-25-10, 12:50 PM | #377 | ||
Any drilling rig that works is a good drilling rig. If I'm interpreting the photos correctly, you have some kind of swivel and you are using city water to flush out the debris, is that correct? Here was my experience, might be helpful to you: Quote:
Regards, -AC_Hacker Last edited by AC_Hacker; 11-25-10 at 01:08 PM.. |
11-25-10, 04:09 PM | #378 |
Finally we can see some real work and not bla bla bla. Soon you will see the reality is a bit different then theory. Good luck. I will wait until spring (we just had almost a foot of snow today) and do my drilling. At 60 feet I was thinking "not a big deal to go to 120" but at 70 feet i changed my mind (reality changed it). I am getting some extra drill bits (real ones). I really do not want to give up an idea about 120 feet holes and drill extra 6 holes even more shallow. But as I said theory and reality are different.
11-25-10, 08:04 PM | #379 | |
I know you only went down a couple feet so you might not have had to flush the inside of the pipe but can I assume you would pull the pipe out and flush it away from the borehole? Vlad, what method(s) did you use to get down to 70 feet? |
11-26-10, 02:26 AM | #380 |
I built a monster compare what pachai and AC-hacker used. I used mud rotary method of drilling. You can find some pics on page 29. I changed many things since that but I went toward bigger stronger.... My drilling rig has hydraulic drive with over 4000 lb-in torque. I used 15 hp gas engine but switched to 5 hp electric. I am waiting for spring. I have no reason to fight weather
Gravel actually is very difficult to drill. You can not use regular bit because it is very hard and you can not use tricone bit because it gets stuck. Last edited by Vlad; 11-26-10 at 02:32 AM.. |
Tags |
air conditioner, diy, gshp, heat pump, homemade |
