Old 02-26-13, 08:00 AM   #1
Default Compact, portable and affordable! Solar DHW?
portable solar water heater | Solaris Energy
I'm thinking the capture area is a bit smallish.. Comments?
Old 02-26-13, 08:12 AM   #2
Agreed, collector looks very small. Perhaps not bad for 35 gallons... I think I recall the general rule of thumb is about 2 gallons of storage per square foot of collector. So you're only talking 17.5 square feet. Hot water general guidelines is roughly 40 square feet per person in your house for the first two peple, then 20 sqft for each after that. At least thats what I've heard.
Wonder what the price is?
Old 02-26-13, 08:49 AM   #3
Their spec says 14.5 sqft.. Is that about the same size as a 46"x46" box collector?
Old 02-26-13, 11:12 PM   #4
I like the premise but feel a Thinner longer/wider rectangle shape would work faster/hotter better.
Thinking out loud here..
A homemade one made from Stainless steel or Aluminum.
Possible a ready made fuel tank designed for a power boat ,cut open then weld heat dissipating fins inside, welded back up and painted Flat Black.
A used tank (quite cheap)can be filled with water and cut open.
Old 02-27-13, 05:08 AM   #5
Those things are interesting but definitely made for southern climates or for 6 months of the year. The European rule of thumb is 1m2 for each person in the house gives 50% of the DHW annually...in europe. Since there is an aperture area of just over 1.3m2 (14ft2), I would suggest that this would be good for 1 average American for at most 1/2 the year.
None the less, if it is inexpensive, it may be worth it.
The idea of cutting a standard water heater in half won't fly because the it has a glass lining which will crack and corrode very quickly. Aluminum or stainless containers can be found in many scrap yards and would make a better tank, no need to cut them open, just paint them with black stove paint and insulate the bottom part. Lots of ways to do this....
Old 02-27-13, 06:19 AM   #6
Default Maybe just get an old RV TV Radome?
Remove the Dish and roll up some water hose inside it?
Old 02-27-13, 09:31 AM   #7
Fordguy64
How much is it? I didn't see a price
Old 02-27-13, 11:53 AM   #8
Maybe it's too new to have a price?
But, it's on Super Sale right now..
Nanosol 35-Gallon Capacity Portable Solar Water Heating Unit
Old 02-27-13, 01:35 PM   #9
So what happens if you don't use hot water for a while? Does it just boil off? I see a problem with stagnation.
Old 02-27-13, 02:05 PM   #10
In cold weather, I see a lot of problems.. It would have to taken inside or drained each night, and on overcast days..
