#81 |
![]() Have you talked to the owner of the business personally? If not do that today.
Maybe you can get this resolved.
The Following User Says Thank You to pinballlooking For This Useful Post: | Roostre (11-10-16) |
#82 |
![]() Roostre,
I forgot that you are in a snow belt area (roof loading). I can tell you that the additional static load of the proposed PV system is only a few lbs per sq foot (racking, panels, wire and roof attachments). Note that when you are walking on a roof, there can be a load of some 75 lbs per sq ft (each footprint = 75lbs). Just don't stand on one leg! This PV static load is FAR less than snow load, but the permitting people want to know if the snow loading plus the PV system is excessive. Bottom line - it is not. Wish I could write you a letter . . . . . Steve
The Following User Says Thank You to stevehull For This Useful Post: | Roostre (11-10-16) |
#83 | |
EcoLearner
![]() Quote:
Around 5PM yesterday I asked him if he was able to complete the permitting and no response whatsoever. I will call the owner again today. I plan to ask him for proof of submission (receipt from the city) and a copy of the plans by noon. If they do not comply I will start the process with Visa to request a refund, which may well end up in court. ![]() Then I will be back at square one and needing a structural engineers stamp. |
#84 |
EcoLearner
![]() Well, it gets even better!
I finally managed to get the subcontractor to send me the engineering sheets, He was "on his way" to pull the permit. I check it over and he has used the wrong racking for the engineering!!!! No way this happens before snow falls. Probably no way before the 31st of December. I am so screwed. |
#85 |
EcoLearner
![]() Just home from work and I just went through the "permit package" that these guys sent me.
It has the system size wrong on the front page title. It says 7.42kw They have the wrong panels and a different size 265w vs. the 270w it should be. The racking is wrong as I posted above. There is no letter from a structural engineer. It looks like copy and paste or some seriously shoddy work. The guy who sent them says " I just turn in what I'm given." He says the owner gave him the wrong information. The only thing that is right is the inverter. He says he already turned it in to the city and they told him about a 17 day wait. Not sure if this is 17 business days or calendar, but either way its into December before they look at it. If it has to be fixed (which no letter from a structural engineer is what I see as an issue) it will get kicked back into January and I lose the tax credit. I talked to another company today about this. They told me that if I can get them the information quickly they can get the engineering letter and completed package by November 18th. So here I sit trying to decide if I ride this fiasco out or cancel the deal and pay this other guy $550 and re-submit the correct information on the 18th???? We really, really need the tax credit this year. ![]() Good news is that this is a first world problem and I know we are blessed that this is the biggest problem in our lives. I'm grateful to be in this position, even if it has been nerve wracking at times. ![]() ![]() |
#86 | |
DIY Geek
![]() Quote:
You need a PE familiar with ASCE 7-05. The phone book should have several. Some will attempt to tell you you are crazy want to do a PV self-install. I had one of those, and I will never call that PE back for any future work, period. I also followed up with my friend the local architect who gave me that PE's number. Like you, I'm a doer. Many of the PE drawings in my permitting set were actually drawn by me. Much of my livelihood is made using AutoCAD, yet my PE sketches were mainly hand drawn sketches by me showing precisely how the (tile hook) mounts would attach to the trusses in the attic without directly bolting through my metal roof tiles. My PE didn't need to draw these for me, he simply needed to review and approve them. Rather than draw my graphical sketches, he needed to tell me what size and length bolts met the uplift load calculations he ran, and how many total mounts were necessary to meet his mathematical criteria. My PE drawings have numerous pages of mathematical calculations showing the area of the array, and the uplift created by this giant wing bolted to my roof. The PE I used was already familiar with my house from previous structural upgrades to mitigate potential wind damage. I believe I even did some of those drawings for him when we were moving windows in the second floor walls and installing impact windows... |
The Following User Says Thank You to where2 For This Useful Post: | Roostre (11-11-16) |
#87 | |
EcoLearner
![]() Quote:
The owner has reached out and he believes that the details aren't important as long as we get the electrical, layout, and loading correct. He says (in writing) that he will re-engineer it on his dime if that happens and make sure that it gets done prior to years end. His statements and a long text discussion with the installer last night has calmed my fears a bit. Getting it in writing helps. It boiled down to a miscommunication from Party A to Party B, then multiplied by not sending me a "proof" or something before going to the city. Miscommunication seems to be a root cause of 99% of the issues in life. Hopefully they learn something from the issue. |
#88 |
![]() In my opinion if you want to get a rough estimate of a solar panel cost it might be depend upon your location or the avg. electrical consumption in your area. If you want to know the accurate cost then have a look to your power bills and find the avg. kWh per month of your house uses.
#89 |
EcoLearner
![]() Yeah, for sure Terry.
My permit was finally processed by the city and denied due to no "wet" engineering stamp (Tuesday). I'm told by the solar company that did my package it will be done and turned back in Wednesday. Snowed last night, so installation is looking to be a dangerous endeavor now. |
#90 |
Banned
![]() As of early 2016, most U.S homeowners are paying $3 to $4 per watt to install a solar panel system, and the average cost per watt in the U.S. is $3.57 per watt. Using the national average for pv system size at 5 kW (or 5000 watts), the average cost of solar: $12,500 (after the Federal ITC discount).
That’s 12 percent lower than it was a year ago, and solar panel system costs are continuing to fall. However, to really understand what a single solar panel will cost and what a complete solar system will cost, it’s important to compare prices quoted to homeowners in your area – total costs can vary depending on the state that you live in. |
