Old 10-25-17, 08:58 AM   #81
WyrTwister
In standard residential split system central heat pump systems , the heat strip may be turned on during defrost to prevent colt air from being blown into the room .
I think our 2 MS HP's just run the indoor fan , very slowly during defrost .
As I said , neither have resistance heat . And they wewe both bottom line ( in cost ) or close to bottom line units .
Best of luck to you , :-)
Wyr
God bless
Old 10-25-17, 10:36 AM   #82
That feature is nice it could be replicated using a electric heater and a temperature controller , when the temp probe senses cold air it could be set to kick on a electric heater via its circuit to keep some heat output going threw defrost. It would at least add heat to the room during the period.
With that being said I ordered a inkbird 308 temperature controller that I will use this winter to control a ventilation fan and run a electric heater when the heat pump is in its off mode.
Doing it this way will allow the heat pump (crappy portable one) to be left at a lower setting to stave off defrost cycles in cold weather.
Old 10-29-17, 10:13 PM   #83
Default Fix for the auxiliary heat
Fix for that pesky auxiliary heat
Old 12-29-17, 09:51 PM   #84
nokiasixteth
Well next week the mini will be getting a brutal workout . It is supposed to dip into the teens here in ms . Strange weather were having . The mini performed flawless during the winter snow we had. If anyone is looking into buying a mini split . I have the figures on how i sized mine back on page 4. If anyone has a better cheaper way let me in on it As most know the higher the hspf rating the more efficient it will be at putting out heat.
Old 01-06-18, 09:11 PM   #85
nokiasixteth
So its goin to look like i will be heating my other half of my place with mini split. I really dont want to use that inefficient oil heater but looks like i will have to bring the old thing out and sit it in my living room and shut off each room to get a reading and avg temp. Hopefully i will be able to do that around march . I have been having to heat it with wood for the past week or so . Its been awful cold .
