11-10-13, 02:34 PM | #81 | |
11-10-13, 07:19 PM | #82 |
On bending the lines, they make a ratcheting tubing bender that apparently works really well even for larger suction lines. Also tape up (or cap) the ends before pushing it through the wall so dirt doesn't get inside.
11-10-13, 07:23 PM | #83 | |
Not talking about expansion in this case. Just the opposite. con·dense verb 1. make (something) denser or more concentrated.
11-10-13, 07:37 PM | #84 |
The line came capped off so this made it so I would not get dirt in the lines when running them.
The good The pressure test went well. I have installed the disconnect and the breaker is in all the wiring is done. I vacuumed down one side to 143 the other side to 119. The bad. But when the Freon was released I heard nothing. I thought maybe it was because the vacuum pump was running. The second one I turned off the pump and I still heard no Freon going into the lines. Last edited by pinballlooking; 11-13-13 at 09:11 AM.. |
11-10-13, 07:43 PM | #85 | |
Are you implying , the condenser / compressor had no R410a in it ? That would not be good . :-( I dumbed up and caused a leak at the small flare nut , at the service valve . :-( I was finishing up , insulating the last few inches of lines , at the service valves . And the service valves them selves . I wiggled the small line , causing the leak . :-( This resulted in my having to buy a 25 lb jug of R410a and gassing it back up . At least I still have almost a full jug of R410a . God bless Wyr Last edited by WyrTwister; 11-10-13 at 07:52 PM.. |
11-10-13, 07:48 PM | #86 | |
But that was in cooling mode , on a late ( HOT ) summer afternoon . Maybe , some one that knows more than I can supply you with better info ? Best of luck ! :-) God bless Wyr Have no idea of the pressures in cold weather and / or in HP mode ? Last edited by WyrTwister; 11-10-13 at 07:53 PM.. |
11-10-13, 07:56 PM | #87 |
I am really wondering if the unit had any R410A in it. When I installed the smaller MS unit I heard the Freon release. I did this step exactly same way I did the first MS but I had to do it twice on this unit. When I took off the vacuum line there was pressure there.
I have not put the gauges back on it yet but I guess I need to do that. This is new to me now. Do I close off the gas side connect the gauges open the one side on the gauges then open the gas valve again? I bought some valves with two inches hose the will help me with this. I do not want to turn it on until I know the Freon is good. |
11-10-13, 08:51 PM | #88 |
When I cracked the Allen wrench and hit the cut-off for the vac line,
there was still pressure in the schrader valve/cut-off fitting. Because, the pin was still pushed in.. After doing the soap bubble test, I very quickly unscrewed the fitting, which released a small amount of R410A into earth's fragile biosphere.. (Sorry). If you want to see if there is R410A in a system, take off the cap, and push in on the schrader valve pin.. If it's charged, your finger tips will get frost bite. If it's not charged, nothing will happen.. Maybe an inrush of air.. So don't hold it open too long, in either case..
The Following User Says Thank You to Xringer For This Useful Post: | pinballlooking (11-10-13) |
11-10-13, 09:03 PM | #89 |
I shut off the valve and was going to hook up the inline value and my gauges but as you said just starting to do that cold Freon came out just a touch so I just stopped. I closed it all back up and fired up the system. It is working nicely right now 120 deg heat very nice. Maybe I did not hear the freon when I released it because it is colder out I am not sure but it all seems good right now.
11-10-13, 10:19 PM | #90 |
I really doesn't make much noise, unless you really crank open the valve quickly..
If you still had your vac pump running, you might not be able to hear the gas hissing.. 120F sounds like it's working okay! Get those caps on nice and snug and sit back and enjoy the warmth..
