03-05-17, 11:18 PM | #801 |
I cleaned out my front grow bed. That was a pain I need to add a radial flow filter back into the system.
I had gloves on but my hands are still sore from the big job. Check out this tomato root ball. It was loaded with worms. Crazy looking The bed looks so empty. The bed had been running nonstop. Those tomato plants were over a year old and still producing tomatoes lots of them. The water was not flowing away from the end without drain. That end of the bed gets more solids. I took out about 60 gallons of rock. I piped the beds water flow out of the bed away from the sump tank and out the vent window. I used a hose with a good sprayer to wash the rock in the bed I took a 5 gallon bucket and would bale out the dirty water. It was a lot of work but all rock got a very good wash down. Three is a bunch of worms in that bed but I am sure I need to add a filter back into this system
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 03-07-17 at 07:33 AM.. |
03-09-17, 03:56 PM | #802 |
My greenhouse web monitoring has been great. I can view it on my phone over 4G cell phone network.
I have one sensor that shows my greenhouse temp. At the hottest part of the day it would show 31 degrees or a low temp that would set off low temp alarm. Then it would go back to like today 80 degrees. I have another sensor to replace this sensor. So I went out to do that today it had alarmed 3 times. Come to find out when I went to take the two wires one was not screwed down it was just stuffed in there. So issue solved I now have both leads screwed down and it is working good again. My wife did some research for salt tolerant strawberries we bought three different kinds. Hopefully they will do better. My other strawberries were doing good but when I salted for health of my fish. This killed my strawberries.
03-14-17, 10:40 AM | #803 |
The strawberries are planted and starting to wake up. These types are said to be more salt tolerant.
We got three different types to see which one do better. Camarosa Buy Camarosa Strawberry Plants - Sakuma Sakuma Bros. Online Store San Andreas Buy San Andreas Strawberry Plants - Sakuma Bros. Online Store Albion Albion Strawberry Plants - US Berry Plants Online Store We bought then from USberryPlants My wife did some research looking for a more salt tolerant berry hopefully these will work good.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 03-15-17 at 10:03 AM.. |
The Following User Says Thank You to pinballlooking For This Useful Post: | Daox (03-15-17) |
03-22-17, 10:44 AM | #804 |
I was away for about a week and the strawberries are doing well.
Back home and eating fresh salad.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 03-22-17 at 12:54 PM.. |
03-27-17, 09:49 AM | #805 |
The bed is slowly filling up.
We have strawberries Two kinds of tomatoes Two jalapeno peppers Three Pimiento peppers Catnip my son talked me into it. Parsley. I need to start more lettuce I am trying for a more balanced grader this year.
03-28-17, 03:50 PM | #806 |
I think I am going to screen my vents this summer. The wasps have discovered the greenhouse more this spring. I am thinking about stapling the screen at the top that using Velcro on the sides and bottom.
This will give me access to my auto vent openers. I will not have it screened tight to let the vent work their magic. I am concerned about reducing air flow. I am thinking about adding an oscillating fan. I have enough extra solar power to run the fan and this would keep no mildew on the plants closest to the barrels. I would probably just run it during the day.
03-28-17, 03:58 PM | #807 |
Can you make a little box with screen and put it around the vents? I wouldn't think the screen would affect the air flow much. Not if there's a good solar driven air pressure.
Current projects Chevy Volt battery pack conversion To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Blog that is down right now but will return To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Business where I sell solar stuff [url]https://www.bobolinksolar.com |
03-28-17, 06:47 PM | #808 |
That made me wonder about honey bees.. What plants need them? Found it..
Vegetable Crops That Do Not Need Pollinators - HorticultureHorticulture
03-28-17, 10:52 PM | #809 |
I never get bees in the greenhouse so I do self-pollination with a toothbrush
I put a q tip on the end of mine.
03-29-17, 10:12 AM | #810 | |
It is already tight to walk in front grow bed. If I can help it I don’t want to make it even harder to walk up there. I just ordered a fan for the greenhouse MaxxAir 18" High Velocity Wall Mount Fan $54.88 We added some spinach.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 03-30-17 at 01:22 PM.. |
